Engineering Solutions
Abaqus to Nastran Conversion
The Abaqus to Nastran conversion tool uses an open conversion scheme; you can specify different mappings in the configuration file. Care has to be taken so that the element and property mappings are consistent. A valid mapping scheme is provided in the ConfigurationFile.txt file. This document explains the scope and limitations of the mapping scheme.
Elements
HyperMesh elements have two basic attributes – configuration (or config) and type. The "config" defines the basic geometrical shape of an element. For example, tria3 configuration is a 3 node triangular element and hexa8 is an 8-node hexahedral element. The "type" defines the solver specific element type of a particular configuration. For example, the 4-node quadrilateral (quad4) element in Abaqus can be any of the following types: S4, S4R, M3D4, R3D4 and so on. The Element Types panel shows all supported element configurations and their types for a user profile.
For a specific configuration, you can map any supported Abaqus element type to any supported Nastran element type, or vice versa. For example, for an Abaqus to Nastran direction, several 2-noded element configurations such as spring, rigid, bar2, rid, and so on are supported. Because all of them are 2-noded elements, conversion across these configurations is also allowed for some element types. For example, CBUSH is of "spring" configuration in the Nastran user profile and CONN3D2 is of "rod" configuration in the Abaqus user profile. It is possible to map a CBUSH to CONN3D2 even though their configurations are different. The element mapping scheme must be under the *ElemTypeConversion block in the ConfigurationFile.txt file. You need to provide both configuration and type information to specify the element mapping scheme as shown for the Abaqus to Nastran direction below:
HM configuration
Abaqus type
Nastran type
Mass
MASS
CONM2
ROTARYI
CONM2
SPRING1
CELAS1, CELAS2, CBUSH
DASHPOT1
CDAMP1
CONN3D2
CBUSH
CONN2D2
CBUSH
rigid
BEAM
RBE2
LINK
RBE2
PIN
RBE2
TIE
RBE2
KINCOUP
RBE2
COUP_KIN
RBE2
COUP_DIS
RBE2
RB3D2
RBE2
R2D2
RBE2
RAX2
RBE2
RB2D2
RBE2
rbe3
DCOUP3D
RBE3
COUP_DIS
RBE3
DCOUP2D
RBE3
rigidlink
KINCOUP
RBE2
RB3D2
RBE2
BEAM
RBE2
LINK
RBE2
PIN
RBE2
TIE
RBE2
COUP_KIN
RBE2
COUP_DIS
RBE3
R2D2
RBE2
RAX2
RBE2
RB2D2
RBE2
spring
SPRING2
CELAS1,CBUSH
SPRINGA
CBUSH
DASHPOT2
CDAMP1, CBUSH
DASHPOTA
CBUSH
JOINTC
CBUSH
bar2
B31
CBAR,CBEAM
B31H
CBAR,CBEAM
B33
CBAR,CBEAM
B33H
CBAR,CBEAM
B31OS
CBAR,CBEAM
B31OSH
CBAR,CBEAM
PIPE31
CBAR,CBEAM
PIPE31H
CBAR,CBEAM
ELBOW31
CBAR,CBEAM
ELBOW31B
CBAR,CBEAM
ELBOW31C
CBAR,CBEAM
AC1D2
CBAR,CBEAM
GK3D2
CBAR,CBEAM
GK3D2N
CBAR,CBEAM
SAX1
CBAR,CBEAM
B21
CBAR,CBEAM
B21H
CBAR,CBEAM
B23
CBAR,CBEAM
B23H
CBAR,CBEAM
PIPE21
CBAR,CBEAM
PIPE21H
CBAR,CBEAM
F2D2
CBAR,CBEAM
FAX2
CBAR,CBEAM
bar3
B32
CBAR,CBEAM
B32H
CBAR,CBEAM
B32OS
CBAR,CBEAM
B32OSH
CBAR,CBEAM
PIPE32
CBAR,CBEAM
PIPE32H
CBAR,CBEAM
ELBOW32
CBAR,CBEAM
AC1D3
CBAR,CBEAM
MGAX2
CBAR,CBEAM
SFMAX2
CBAR,CBEAM
SFMGAX2
CBAR,CBEAM
SAX2
CBAR,CBEAM
B22
CBAR,CBEAM
B22H
CBAR,CBEAM
PIPE22
CBAR,CBEAM
PIPE22H
CBAR,CBEAM
rod
T3D2
CROD
T3D2H
CROD
T3D2T
CROD
T3D2E
CROD
MGAX1
CROD
SFMAX1
CROD
SFMGAX1
CROD
CONN3D2
CBUSH
T2D2
CROD
T2D2H
CROD
T2D2T
CROD
T2D2E
CROD
GK2D2
CROD
GK2D2N
CROD
CONN2D2
spring CELAS1,CELAS2,CBUSH
gap
GAPUNI
CGAP
GAPCYL
CGAP
GAPSPHER
CGAP
tria3
S3
CTRIA3,CTRIAR
S3R
CTRIA3,CTRIAR
STRI3
CTRIA3,CTRIAR
M3D3
CTRIA3,CTRIAR
SFM3D3
CTRIA3,CTRIAR
R3D3
CTRIA3,CTRIAR
DS3
CTRIA3,CTRIAR
CPE3
CTRIA3,CTRIAR
CPE3H
CTRIA3,CTRIAR
CPE3E
CTRIA3,CTRIAR
CPS3
CTRIA3,CTRIAR
CPS3E
CTRIA3,CTRIAR
CAX3
CTRIA3,CTRIAR
CAX3H
CTRIA3,CTRIAR
CAX3E
CTRIA3,CTRIAR
CGAX3
CTRIA3,CTRIAR
CGAX3H
CTRIA3,CTRIAR
AC2D3
CTRIA3,CTRIAR
ACAX3
CTRIA3,CTRIAR
DCAX3
CTRIA3,CTRIAR
DCAX3E
CTRIA3,CTRIAR
DC2D3
CTRIA3,CTRIAR
DC2D3E
CTRIA3,CTRIAR
quad4
S4
CQUAD4,CQUADR
S4R
CQUAD4,CQUADR
S4R5
CQUAD4,CQUADR
M3D4
CQUAD4,CQUADR
M3D4R
CQUAD4,CQUADR
SFM3D4
CQUAD4,CQUADR
SFM3D4R
CQUAD4,CQUADR
R3D4
CQUAD4,CQUADR
DS4
CQUAD4,CQUADR
GK3D4L
CQUAD4,CQUADR
GK3D4LN
CQUAD4,CQUADR
F3D4
CQUAD4,CQUADR
CPE4I
CQUAD4,CQUADR
CPE4
CQUAD4,CQUADR
CPE4H
CQUAD4,CQUADR
CPE4IH
CQUAD4,CQUADR
CPE4R
CQUAD4,CQUADR
CPE4RH
CQUAD4,CQUADR
CPE4T
CQUAD4,CQUADR
CPE4HT
CQUAD4,CQUADR
CPE4E
CQUAD4,CQUADR
CPS4
CQUAD4,CQUADR
CPS4I
CQUAD4,CQUADR
CPS4R
CQUAD4,CQUADR
CPS4T
CQUAD4,CQUADR
CPS4E
CQUAD4,CQUADR
CAX4
CQUAD4,CQUADR
CAX4H
CQUAD4,CQUADR
CAX4I
CQUAD4,CQUADR
CAX4IH
CQUAD4,CQUADR
CAX4R
CQUAD4,CQUADR
CAX4RH
CQUAD4,CQUADR
CAX4T
CQUAD4,CQUADR
CAX4HT
CQUAD4,CQUADR
CAX4E
CQUAD4,CQUADR
CAXA4N
CQUAD4,CQUADR
CAXA4HN
CQUAD4,CQUADR
CAXA4RN
CQUAD4,CQUADR
CAXA4RHN
CQUAD4,CQUADR
CGAX4
CQUAD4,CQUADR
CGAX4H
CQUAD4,CQUADR
CGAX4R
CQUAD4,CQUADR
CGAX4RH
CQUAD4,CQUADR
AC2D4
CQUAD4,CQUADR
ACAX4
CQUAD4,CQUADR
DC2D4
CQUAD4,CQUADR
DC2D4E
CQUAD4,CQUADR
DCAX4
CQUAD4,CQUADR
DCAX4E
CQUAD4,CQUADR
DCCAX4
CQUAD4,CQUADR
DCCAX4D
CQUAD4,CQUADR
GKPS4
CQUAD4,CQUADR
GKPE4
CQUAD4,CQUADR
GKPS4N
CQUAD4,CQUADR
tria6
STRI65
CTRIA6
M3D6
CTRIA6
SFM3D6
CTRIA6
DS6
CTRIA6
CPE6
CTRIA6
CPE6H
CTRIA6
CPE6M
CTRIA6
CPE6MH
CTRIA6
CPS6
CTRIA6
CPS6M
CTRIA6
AC2D6
CTRIA6
ACAX6
CTRIA6
DCAX6
CTRIA6
DC2D6
CTRIA6
DCAX6E
CTRIA6
DC2D6E
CTRIA6
CAX6
CTRIA6
CAX6H
CTRIA6
CAX6M
CTRIA6
CAX6MH
CTRIA6
CGAX6
CTRIA6
CGAX6H
CTRIA6
quad8
S8R
CQUAD8
S8R5
CQUAD8
S8RT
CQUAD8
M3D8
CQUAD8
M3D8R
CQUAD8
SFM3D8
CQUAD8
SFM3D8R
CQUAD8
DS8
CQUAD8
CPE8
CQUAD8
CPE8H
CQUAD8
CPE8R
CQUAD8
CPE8RH
CQUAD8
CPS8
CQUAD8
CPS8R
CQUAD8
AC2D8
CQUAD8
ACAX8
CQUAD8
DC2D8
CQUAD8
DCAX8
CQUAD8
DCAX8E
CQUAD8
DC2D8E
CQUAD8
CAX8
CQUAD8
CAX8H
CQUAD8
CAX8HT
CQUAD8
CAX8R
CQUAD8
CAX8RH
CQUAD8
CAX8RHT
CQUAD8
CAX8RT
CQUAD8
CGAX8
CQUAD8
CGAX8H
CQUAD8
CGAX8R
CQUAD8
CGAX8RH
CQUAD8
CAXA8N
CQUAD8
CAXA8HN
CQUAD8
CAXA8PN
CQUAD8
CAXA8RN
CQUAD8
CAXA8RHN
CQUAD8
CAXA8RPN
CQUAD8
tetra4
C3D4
CTETRA
C3D4H
CTETRA
C3D4E
CTETRA
AC3D4
CTETRA
DC3D4
CTETRA
DC3D4E
CTETRA
penta6
C3D6
CPENTA
C3D6H
CPENTA
C3D6E
CPENTA
AC3D6
CPENTA
GK3D6
CPENTA
GK3D6N
CPENTA
SC6R
CPENTA
COH3D6
CPENTA
hex8
C3D8I
CHEXA
C3D8
CHEXA
C3D8T
CHEXA
C3D8H
CHEXA
C3D8HT
CHEXA
C3D8IH
CHEXA
C3D8R
CHEXA
C3D8RH
CHEXA
C3D8E
CHEXA
AC3D8
CHEXA
DC3D8
CHEXA
DC3D8E
CHEXA
DCC3D8
CHEXA
DCC3D8D
CHEXA
SC8R
CHEXA
COH3D8
CHEXA
tetra10
C3D10
DC3D10
C3D10H
DC3D11
C3D10M
DC3D12
C3D10MH
DC3D13
C3D10E
DC3D14
DC3D10E
DC3D15
AC3D10
DC3D16
DC3D10
DC3D17
penta15
C3D15
CPENTA
C3D15H
CPENTA
C3D15E
CPENTA
AC3D15
CPENTA
DC3D15
CPENTA
DC3D15E
CPENTA
hex20
C3D20
CHEXA
C3D20H
CHEXA
C3D20R
CHEXA
C3D20RH
CHEXA
C3D20E
CHEXA
C3D20RE
CHEXA
C3D20T
CHEXA
C3D20HT
CHEXA
C3D20RT
CHEXA
C3D20RHT
CHEXA
DC3D20
CHEXA
AC3D20
CHEXA
DC3D20E
CHEXA
Abaqus CONN3D2 connector elements are converted to Nastran CBUSH, PBUSH using the following guidelines:
Connector1 types converted:
oAXIAL: Active = [1], Rigid = [-]
oCARTESIAN, PROJECTION CARTESIAN: Active = [123], Rigid = [-]
oJOIN: Active = [-], Rigid = [123]
oRADIAL-THRUST: Active = [13]*, Rigid = [-]
*Requires cylindrical system
oSLIDE-PLANE: Active = [23], Rigid = [1]
oSLOT: Active = [1], Rigid = [23]
Connector2 types converted:
oALIGN: Active = [-], Rigid = [456]
oCARDAN, EULER, ROTATION, FLEXION-TORSION, PROJECTION FLEXION-TORSION: Active = [456], Rigid = [-]
oREVOLUTE: Active = [4], Rigid = [56]
Special assembled Connector1 types:
oBEAM, WELD = (JOIN + ALIGN): Active = [-], Rigid = [123456]
oCYLINDRICAL = (SLOT + REVOLUTE): Active = [14], Rigid = [2356]
oHINGE = (JOIN + REVOLUTE): Active = [4], Rigid = [12356]
oPLANAR = (SLIDE-PLANE + REVOLUTE): Active = [234], Rigid = [156]
oTRANSLATOR = (SLOT + ALIGN): Active = [1], Rigid = [23456]
oBUSHING = (PROJECTION CARTESIAN + PROJECTION FLEXION-TORSION): Active = [123456], Rigid = [-]
PBUSH stiffness and damping values (Ki, Bi) for active DOFs are mapped from *CONNECTOR BEHAVIOR material data. Rigid DOFs map to RIGID option inside PBUSH.
CBUSH orientation is mapped from *CONNECTOR SECTION Orientation system.
oOnly 1 Orientation system can be mapped to CBUSH CID.
oIf 2 Orientation systems are present in the Abaqus card, HyperMesh only maps the first one.
It is also possible to use a simplified conversion of Abaqus connectors (CONN3D2) to rbe2 elements when modifying the ConfigurationFile.txt file. Change the entry for rod element type configuration to:
         rod,CONN3D2 rigid,rbe2
CONN3D2 elements will now be converted to RBE2 elements. Depending on the connection type set in the CONNECTOR SECTION (such as AXIAL or HINGE), degrees of freedom will be set for the RBE2 element. If systems are associated to the connector elemental nodes they will be assigned to the nodes of the RBE2 as well. Not all connection types are supported. If a system is ignored by a particular CONNECTOR SECTION, it will not be assigned to the nodes of the RBE2 either.
These connector types are currently considered in conversion: AXIAL, JOIN, LINK, SLIDE-PLANE, SLOT, ALIGN, REVOLUTE, BEAM, CYLINDRICAL, HINGE, PLANAR, TRANSLATOR, WELD.
*COUPLING/*KINEMATIC constraints with element based surfaces (currently mapped to groups in HyperMesh) are converted into RBE2 rigid elements. *COUPLING/*DISTRIBUTING constraints are converted to RBE3 elements.
All SPRING and DASHPOT related conversions (including JOINTC) map to CELAS1, CDAMP1, or CBUSH/PBUSH using the following guidelines:
SPRING1/2 without ORIENTATION converts to CELAS1
SPRINGA or SPRING1/2 with ORIENTATION converts to CBUSH/PBUSH/PBUSHT with K/KN lines. For SPRING1/2, ORIENTATION maps to CBUSH, CID.
DASHPOT1/2 without ORIENTATION converts to CDAMP1
DASHPOTA or DASHPOT1/2 with ORIENTATION converts to CBUSH/PBUSH/PBUSHT with B line. For DASHPOT1/2, ORIENTATION maps to CBUSH, CID.
Sectional Properties
The table below shows supported sectional property mapping between Abaqus and Nastran. Some of the properties in one solver can be converted to two different sections in the other solver. For an Abaqus to Nastran conversion, for example, *DASHPOT can be converted to *PELAS or PDAMP. The property mapping scheme can be edited under the *PropertyConversion block in the ConfigurationFile.txt file.
Please note that the property conversion scheme and corresponding element conversion scheme must be consistent. For example, if you define *CONNECTOR SECTION to PBUSH at the property mapping scheme, the corresponding element CONN3D2 must map to CBUSH in the element mapping scheme.
For SOLID SECTION the converter will always convert to PSOLID unless the property has a data line indicating a crossectional area for a truss element. In this case conversion results in a PROD property.
For BEAM (GENERAL) SECTION the algorithm automatically decides which property to convert to depending on the element type chosen in the ElementTypeConversion section of the ConfigurationFile.txt. For example, if you want to convert B31 elements to CBAR, the beam property will get converted to a PBAR or PBARL property. If you choose to convert B31 elements to CBEAM, then the converter creates PBEAM or PBEAML properties accordingly. The same logic applies to B32 elements; the difference is that they are changed to first order beam elements first on conversion.
Abaqus type
Nastran type
*BEAM GENERAL SECTION
PBAR(L), PBEAM(L)
*BEAM SECTION
PBAR(L), PBEAM(L)
*CONNECTOR SECTION
PELAS,PBUSH
*DASHPOT
PELAS,PDAMP
*GAP
PGAP
*MASS
CONM2
*MEMBRANE SECTION
PSHELL
*ROTARY INERTIA
CONM2
*SHELL GENERAL SECTION
PSHELL
*SHELL SECTION
PSHELL
*SOLID SECTION
PSOLID
*SPRING
PELAS, PBUSH
*SOLID SECTION (Homogeneous)
PROD
*SHELL GENERAL SECTION (Homogeneous)
PSHELL
*SHELL SECTION (Homogeneous)
PSHELL
*SHELL GENERAL SECTION (User)
PSHELL
*SHELL SECTION (Composite)
PCOMP, PCOMPG
*SHELL GENERAL SECTION (Composite)
PCOMP, PCOMPG
Materials
The table below shows supported material mapping between Abaqus and Nastran. The material mapping scheme can be edited under *PropertyConversion block in the ConfigurationFile.txt file.
Abaqus type
Nastran type
*MATERIAL
MAT1, MAT4, MATT1, MATS1
*CONNECTOR BEHAVIOR
PBUSH, PELAS
Loads
HM loads have two basic attributes – configuration (or config) and type. The supported load "configs" are: force, moment, constraint, pressure, temperature, flux, velocity, acceleration and equation. The load "type" defines the solver specific type of a particular configuration. For example, pressure load can be any of the following Nastran types: PLOAD, PLOAD2 or PLOAD4. The Load Types panel shows all supported load configurations and their types for a user profile.
The converter also converts distributed surfaces loads (*DLSOAD) applied on faces of shell or solid elements into pressure loads (PLOAD4).
For a specific configuration, you can map any supported Abaqus load type to any supported Nastran load type. The conversion tool does not support conversion across load configurations. The load mapping scheme can be edited under the *BCsTypeConversion block in the ConfigurationFile.txt file. You need to provide both configuration and type information to specify the mapping scheme as shown below:
HM configuration
Abaqus type
Nastran type
temperature
TEMPERATURE
TEMP
pressure
DLOAD
PLOAD,PLOAD2,PLOAD4
Constraint
ACCELERATION
SPCD
VELOCITY
SPCD
BOUNDARY
SPC,SUPORT
moment
CLOAD
MOMENT
force
CLOAD
FORCE
equation
EQUATION
MPC
Sets
Abaqus type
Nastran type
*NSET
SET
*ELSET
SET
Systems
Abaqus type
Nastran type
*ORIENTATION
CORD2C,CORD2R,CORD2S
*SYSTEM
*TRANSFORM
*TRANSFORM- USER DEFINED NSET
Load Steps and Analysis Type
The conversion tool maps between Abaqus steps and Nastran subcases. It does not convert Abaqus analysis type to the solution type. You must define it manually using the Load Step browser.
The converter converts *STEP into SUBCASE. Load collector references are maintained upon conversion. If multiple load collectors of a particular step contain constraints, an SPCADD card is created automatically. The same happens in case of loads in separate load collectors; a new LOAD card is created on conversion.
See Also:
Abaqus Conversion Tools
