Engineering Solutions
Abaqus to RADIOSS Conversion
Use the Conversion tool to convert an Abaqus explicit file to a RADIOSS file.
1.Load the Abaqus Explicit user profile.
2.Import an Abaqus Explicit model.
3.To run the conversion macro, from the menu bar, select Tools > Convert > Abaqus > To Radioss. The Abaqus to Radioss Conversion tab opens.
4.For Source template, select the source solver version.
5.For Destination Template, select the destination solver version.
6.To start the conversion, click Convert. After the conversion, the selected version of the RADIOSS user profile automatically loads.
7.Review and export the deck using the RADIOSS user profile. Some of the keywords in the Abaqus (explicit) deck are converted to the RADIOSS deck as per the tables below.
Element Mapping
HM configuration, Abaqus (Explicit) type
HM configuration, RADIOSS  type
C3D10M
/BRICK
C3D4
/BRICK
C3D6
/BRICK
C3D8R
/BRICK
S3R
/SH3N
S4R
/SHELL
SC8R
/BRICK
SC6R
/PENTA6
R3D3
/SH3N + /RBODY
R3D4
/SHELL + /RBODY
MASS
/ADMAS
M3D4R/M3D3
/PROP/SHELL
Property Mapping
*SOLID_SECTION and *CONTROL_SECTION
/PROP/SOLID
*SHELL_SECTION and *CONTROL_SECTION
/PROP/SHELL or PROP/TSHELL
*RIGIDBODY
PROP/SHELL or /PROP/SOLID
*MASS
/ADMAS
*SHELL SECTION COMPOSITE
/PROP/TSH_COMP(P22_TSH_COMP)
Material Mapping
ELASTIC, ISOTROPIC
/MAT/ELASTIC
PLASTIC, ISOTROPIC
/MAT/PLAS_TAB
Hyperelastic, Mooney, Rivlin
MAT/OGDEN
Hyperelastic, Ogden
MAT/OGDEN
PLASTIC,JOHNSON COOK
M2PLAS_JOHN_ZERIL
HYPERELASTIC,MARLOW
/MAT/LAW70
ORTHOTROPIC
/MAT/COMPSH
Function Mapping
*AMPLITUDE
/FUNCT, /MOVE_FUNCT
Group Mapping
*NSET
/GRNOD
*ELSET
/GSHEL, /GRSH3N, /GRBRIC
*SURFACE
/GRNOD, /SURF
Load Mapping
*BOUNDARY
/IMPDISP, /IMPVEL, /IMPACC, /BCS
*INITIAL CONDITION
/INIVEL
*CLOAD
/CLOAD
*DLOAD
/GRAV, /PLOAD
Contact Mapping
*TIED, *CONTACT_CLEARANCE, *SURFACE_INTERACTION
/INTER/TYPE2
/INTER/TYPE7
*CONTACT PAIR
/INTER/TYPE24
GENERAL CONTACT
/INTER/TYPE24
Constraints Mapping
*COUPLING KINEMATIC, *COUPLING DYNAMIC
/RBE2, /RBE3
*MPC  BEAM
/RBODY
Output Block  Mapping
*STEP, STEP NAME
/TITLE and /RUN
*DYNAMIC, T_period
/TSTOP
*VARIABLE MASS SCALING
/DT/NODA/CST
*OUTPUT FIELD
/ANIM/DT, /ANIM/VECT/(ACC, VEL, DISP, FINT, PCONT), /ANIM/BRICK/TENS/(STRESS,STRAIN) /ANIM/SHELL/TENS/(STRESS,STRAIN), /ANIM/ELEM/(VONMISES, PRESSURE,EPSP, ENER, DENS)
*OUTPUT  HISTORY
/TFILE, /TH/NODE, /TH/SHEL, /TH/SH3N, /TH/BEAM, /TH/BRIC
See Also:
Abaqus Conversion Tools
