Engineering Solutions
ANSYS to Abaqus Conversion
Use the Conversion tool to convert an ANSYS file to an Abaqus file.
1.Load the ANSYS user profile.
2.Import an ANSYS model.
3.To run the Conversion macro, from the menu bar, select Tools > Convert > ANSYS > To Abaqus. The Conversion tab opens.
4.To start the conversion, click Convert. After the conversion, the Abaqus user profile automatically loads.
5.Review and export the deck in an Abaqus deck. Some of the keywords in the ANSYS deck are converted to the Abaqus deck as per the following tables.
Materials
Modulus of Elasticity, Poisson's ratio and density are mapped.
Elements
ANSYS type
Abaqus type
HM Configuration
MASS21
MASS
Mass
COMBI14
SPRING2
Spring
BEAM4
B31
Bar2
LINK8
T3D2
Rod
SHELL43, SHELL63, SHELL181
S3
Tria3
S4
Quad4
SHELL93
STRI65
Tria6
SHELL93
S8R
Quad8
SOLID45, SOLID62, SOLID64, SOLID69, SOLID70, SOLID96, SOLID97, SOLID164, SOLID185
C3D4
Tetra4
SOLID62, SOLID70, SOLID96, SOLID97, SOLID164
C3D8
Pyramid5
SOLID5, SOLID45, SOLID62, SOLID64, SOLID69, SOLID70, SOLID96, SOLID97, SOLID164, SOLID185
C3D6
Penta6
C3D81
Hex8
SOLID87, SOLID90, SOLID92, SOLID95, SOLID98, SOLID117, SOLID148, SOLID168, SOLID186, SOLID187, SOLID191
C3D10
Tetra10
SOLID90, SOLID95, SOLID117, SOLID186
C3D20
Pyramid13
SOLID90, SOLID95, SOLID117, SOLID147, SOLID186, SOLID191
C3D15
Penta15
Hex20
MPC184
BEAM_RIGID
Rigid
RBE3, CONTA175, TARGE170
COUP_DIS
RBE3
CP
COUP_KIN
Rigid
COMBIN39
SPRINGA
Spring
Properties
ANSYS type
Abaqus type
Convert Parameters
MASS21p
MASS
none
COMBI14p
SPRING
none
BEAM4p, LINK8p
BEAMSECTION
none
SHELL43p, SHELL63p, SHELL93p
SHELLSECTION
Shell Thickness
SOLID45p, SOLID70p, SOLID95p, SOLID117p, SOLID191p
SOLIDSECTION
none
BEAM4p
BEAMGENSECTION
Area, Ixx,Iyy,Izz
Notes:
If ANSYS solid elements do not have a property, then one SOLIDSECTION property will be created by using this conversion tool.
Loads and boundary conditions
Loads and boundary conditions will not be converted on using this conversion tool.
See Also:
ANSYS Conversion Tools
