Engineering Solutions
ANSYS to Nastran Conversion
Use the Conversion tool to convert an ANSYS file to a Nastran file.
1.Load the ANSYS user profile.
2.Import an ANSYS model.
3.To run the Conversion macro, from the menu bar, click Tools > Convert > ANSYS > To Nastran. The Conversion tab opens.
4.Click Convert. After the conversion, the Nastran user profile automatically loads.
Conversion Notes
All ANSYS solid and shell elements that are currently supported are included in the conversion tool.
Material properties – Thermal Conductivity, specific heat, thermal expansion co-efficient can be now converted.
Nonlinear material data and temperature dependent materials defined through TB tables are converted to TABLESx cards inside a MATS1.
2D and 3D Orthotropic properties of E, NU, and Alpha can be converted.
If components or properties do not have a material associated to them on conversion, then MID = 1 will be associated.
On conversion, a model will be cleaned by removing unused sets, ET types, and contact elements.
COMBIN14 elements are now converted to CELAS1 if key option2 for COMBIN14 in ANSYS is defined. If key option 3 is defined, it is converted to 3 coincident CELAS (1 per DOF).
ANSYS BEAM188 converts to CBEAM now [please note section properties defined using SECDATA card in ANSYS are not yet converted].
Forces, Moments, Pressures, Temperatures and Constraints are automatically converted. MODOPT (control cards) will be mapped to EIRGL. ACEL (Control Cards) will be converted to GRAV.
BEAM44 element type end release options defined in KEYOPTIONS 7 and 8 are converted to values in fields PA and PB respectively in the CBEAM card.
BEAM188 section properties are converted from the BeamSection Collector data and not from the EtType Sensor (this is how the BEAM188 section data is modeled in the HyperMesh ANSYS User Profile).
oSECTYPE with TYPE equal to BEAM and SUBTYPEs equal to RECT, CSOLID, CTUBE, I, L, T convert to a PBEAML property with corresponding standard section definition.
oSECTYPE with TYPE equal to BEAM and SUBTYPEs equal to ASEC, QUAD, CHAN, Z, HATS, HREC convert to a PBEAM property with corresponding cross section property values.
MPC184 converts to either a RBE2 rigid element or a CBUSH/PBUSH bushing element depending on the KEYOPT(1) value, as follows:
oKEYOPT(1) equal to 0 converts to RBE2 with constraint DOFs equal to [123]
oKEYOPT(1) equal to 1 converts to RBE2 with constraint DOFs equal to [123456]
oKEYOPT(1) equal to 6 converts to CBUSH + PBUSH
K4 equals <blank>/0.0
K1, K2, K3, K5, K6 equals 1e10
oKEYOPT(1) equal to 8 converts to CBUSH + PBUSH
K1, K4, K5, K6 equals <blank>/0.0
K2, K3 equals 1E10
oKEYOPT(1) equal to 9 converts to CBUSH + PBUSH
K2, K3, K4, K5, K6 equals <blank>/0.0
K1 equals 1E10
oKEYOPT(1) equal to 10 converts to CBUSH + PBUSH
K1 equals <blank>/0.0
K2, K3, K4, K5, K6 equals 1E10
oKEYOPT(1) equal to 11 converts to CBUSH + PBUSH
K1, K4 equals <blank>/0.0
K2, K3, K5, K6 equals 1E10
oKEYOPT(1) equal to 12 converts to CBUSH + PBUSH
K2, K3, K4 equals <blank>/0.0
K1, K5, K6 equals 1E10
oKEYOPT(1) equal to 13 converts to RBE2 with constraint DOFs equal to [123456]
oKEYOPT(1) equal to 14 converts to RBE2 with constraint DOFs equal to [456]
oKEYOPT(1) equal to 15 converts to RBE2 with constraint DOFs equal to [123]
Assumptions
The Conversion tool will only convert entities imported by the ANSYS FE input reader.
For shell elements, constant thickness parts are assumed.
Analysis types assumed: Static – gravity, forces, pressures and constraints; Modal.
Conversion Mapping
Elements
HM config, ANSYS type
HM config, Nastran type
mass, CONTAC175
sets, GRID
mass, MASS21
mass, CONM2
rigid, CP
equation, MPC
rigid, CERIG
rbe2, RBE2
rigidlink, CP
equation, MPC
rigidlink, CERIG
equation, MPC
rbe3/RBE3
rbe3, RBE3
spring, CONBIN14
spring, CBUSH
bar2, BEAM44
bar2, CBEAM
bar2, BEAM188
bar2, CBEAM
bar2, PIPE16
bar2, CBEAM
bar2, BEAM4
bar2, CBEAM
rod, LINK8
rod, CROD
rod, MPC184
rbe2,RBE2 / spring,CBUSH
tria3, PLANE182
tria3, CTRIA3
tria3, SHELL181
tria3, CTRIA3
tria3, SHELL163
tria3, CTRIA3
tria3, PLANE162
tria3, CTRIA3
tria3, SHELL157
tria3, CTRIA3
tria3, SHELL143
tria3, CTRIA3
tria3, SHELL131
tria3, CTRIA3
tria3, PLANE75
tria3, CTRIA3
tria3, PLANE67
tria3, CTRIA3
tria3, SHELL63
tria3, CTRIA3
tria3, SHELL57
tria3, CTRIA3
tria3, PLANE55
tria3, CTRIA3
tria3, SHELL43
tria3, CTRIA3
tria3, PLANE42
tria3, CTRIA3
tria3, SHELL41
tria3, CTRIA3
tria3, PLANE25
tria3, CTRIA3
tria3, PLANE13
tria3, CTRIA3
quad4, PLANE182
quad4, CQUAD4
quad4, SHELL181
quad4, CQUAD4
quad4, SEHLL163
quad4, CQUAD4
quad4, PLANE162
quad4, CQUAD4
quad4, SHELL157
quad4, CQUAD4
quad4, SHELL143
quad4, CQUAD4
quad4, SHELL131
quad4, CQUAD4
quad4, PLANE75
quad4, CQUAD4
quad4, PLANE67
quad4, CQUAD4
quad4, SHELL63
quad4, CQUAD4
quad4, SHELL57
quad4, CQUAD4
quad4, PLANE55
quad4, CQUAD4
quad4, SHELL43
quad4, CQUAD4
quad4, PLANE42
quad4, CQUAD4
quad4, SHELL41
quad4, CQUAD4
quad4, SHELL28
quad4, CQUAD4
quad4, PLANE25
quad4, CQUAD4
quad4, PLANE13
quad4, CQUAD4
tetra4, SOLID185
tetra4, CTETRA
tetra4, SOLID164
tetra4, CTETRA
tetra4, SOLID97
tetra4, CTETRA
tetra4, SOLID96
tetra4, CTETRA
tetra4, SOLID73
tetra4, CTETRA
tetra4, SOLID72
tetra4, CTETRA
tetra4, SOLID70
tetra4, CTETRA
tetra4, SOLID69
tetra4, CTETRA
tetra4, SOLID64
tetra4, CTETRA
tetra4, SOLID62
tetra4, CTETRA
tetra4, SOLID46
tetra4, CTETRA
tetra4, SOLID45
tetra4, CTETRA
tetra4, SOLID285
tetra4, CTETRA
penta6, SOLSH190
penta6, CPENTA
penta6, SOLID185
penta6, CPENTA
penta6, SOLID164
penta6, CPENTA
penta6, VISCO107
penta6, CPENTA
penta6, SOLID97
penta6, CPENTA
penta6, SOLID96
penta6, CPENTA
penta6, SOLID73
penta6, CPENTA
penta6, SOLID70
penta6, CPENTA
penta6, SOLID69
penta6, CPENTA
penta6, SOLID64
penta6, CPENTA
penta6, SOLID62
penta6, CPENTA
penta6, SOLID46
penta6, CPENTA
penta6, SOLID45
penta6, CPENTA
penta6, SOLID5
penta6, CPENTA
hex8, SOLSH190
hex8, CHEXA
hex8, SOLID185
hex8, CHEXA
hex8, SOLID164
hex8, CHEXA
hex8, SOLID97
hex8, CHEXA
hex8, SOLID96
hex8, CHEXA
hex8, SOLID73
hex8, CHEXA
hex8, SOLID70
hex8, CHEXA
hex8, SOLID69
hex8, CHEXA
hex8, SOLID64
hex8, CHEXA
hex8, SOLID62
hex8, CHEXA
hex8, SOLID46
hex8, CHEXA
hex8, SOLID45
hex8, CHEXA
hex8, SOLID5_1
hex8, CHEXA
tria6, PLANE183
tria6, CTRIA6
tria6, SHELL150
tria6, CTRIA6
tria6, PLANE145
tria6, CTRIA6
tria6, SHELL132
tria6, CTRIA6
tria6, SHELL281
tria6, CTRIA6
tria6, PLANE121
tria6, CTRIA6
tria6, SHELL99
tria6, CTRIA6
tria6, SHELL93
tria6, CTRIA6
tria6, SHELL91
tria6, CTRIA6
tria6, PLANE83
tria6, CTRIA6
tria6, PLANE82
tria6, CTRIA6
tria6, PLANE78
tria6, CTRIA6
tria6, PLANE77
tria6, CTRIA6
tria6, PLANE53
tria6, CTRIA6
tria6, PLANE35
tria6, CTRIA6
tria6, PLANE2
tria6, CTRIA6
quad8, PLANE183
quad8, CQUAD8
quad8, SHELL150
quad8, CQUAD8
quad8, PLANE145
quad8, CQUAD8
quad8, SHELL132
quad8, CQUAD8
quad8, SHELL281
quad8, CQUAD8
quad8, PLANE121
quad8, CQUAD8
quad8, SHELL99
quad8, CQUAD8
quad8, SHELL93
quad8, CQUAD8
quad8, SHELL91
quad8, CQUAD8
quad8, PLANE83
quad8, CQUAD8
quad8, PLANE82
quad8, CQUAD8
quad8, PLANE78
quad8, CQUAD8
quad8, PLANE77
quad8, CQUAD8
quad8, PLANE53
quad8, CQUAD8
tetra10, SOLID191
tetra10, CTETRA
tetra10, SOLID187
tetra10, CTETRA
tetra10, SOLID186
tetra10, CTETRA
tetra10, SOLID148
tetra10, CTETRA
tetra10, SOLID117
tetra10, CTETRA
tetra10, SOLID98
tetra10, CTETRA
tetra10, SOLID95
tetra10, CTETRA
tetra10, SOLID92
tetra10, CTETRA
tetra10, SOLID90
tetra10, CTETRA
tetra10, SOLID87
tetra10, CTETRA
penta15, SOLID191
penta15, CPENTA
penta15, SOLID186
penta15, CPENTA
penta15, SOLID147
penta15, CPENTA
penta15, SOLID117
penta15, CPENTA
penta15, SOLID95
penta15, CPENTA
penta15, SOLID90
penta15, CPENTA
hex20, SOLID191
hex20, CHEXA
hex20, SOLID186
hex20, CHEXA
hex20, SOLID147
hex20, CHEXA
hex20, SOLID117
hex20, CHEXA
hex20, SOLID95
hex20, CHEXA
hex20, SOLID90
hex20, CHEXA
Properties
ANSYS type
Nastran type
LINK8P
LINK8P
BEAM4P
PBEAM
BEAM44P
PBEAM
SOLID45P
PSOLID
SOLID46P
PSOLID
SOLID70P
PSOLID
SOLID95P
PSOLID
SOLID97P
PSOLID
SOLID117P
PSOLID
SOLID185P
PSOLID
SOLID191P
PSOLID
SHELL28P
PSHELL
SHELL41P
PSHELL
SHELL43P
PSHELL
SHELL57P
PSHELL
SHELL63P
PSHELL
SHELL91P
PCOMP
SHELL93P
PSHELL
SHELL99P
PCOMP
SHELL131P
PCOMP
SHELL132P
PCOMP
SHELL143P
PSHELL
SHELL150P
PSHELL
SHELL157P
PSHELL
SHELL181P
PSHELL
SHELL281P
PSHELL
PLANE2P
PSHELL
PLANE42P
PSHELL
PLANE82P
PSHELL
PLANE145P
PSHELL
PLANE183P
PSHELL
PIPE16P
PBEAML
COMBIN14P
PBUSH
MASS21P
CONM2
Materials
ANSYS type
Nastran type
MP
MAT1
MPDATA
MAT1
Loads
temperature, BF_TEMP
temperature, TEMP
temperature, IC_TEMP
temperature, TEMP
temperature, D_TEMP
temperature, TEMP
pressure, HFLUX
pressure, PLOAD2
pressure, ConvBulkTe
pressure, PLOAD
pressure, PRESSURE
pressure, PLOAD4
constraint, D_VOLT
constraint, ASET1
constraint, IC_CONSTRNT
constraint, SPCD
constraint, D_CONSTRAIN
constraint, SPC
moment, FORCE2
moment, MOMENT
force, FORCE
force, FORCE
Sets
set
set
Cards
ANSYS type
Nastran type
ACEL
GRAV
Sensors
ANSYS type
Nastran type
Link8
PROD
BEAM4
PBEAM
BEAM44
PBEAM
BEAM188
PBEAML
SOLID5
PSOLID
SOLID45
PSOLID
SOLID46
PSOLID
SOLID62
PSOLID
SOLID64
PSOLID
SOLID69
PSOLID
SOLID70
PSOLID
SOLID87
PSOLID
SOLID90
PSOLID
SOLID92
PSOLID
SOLID95
PSOLID
SOLID96
PSOLID
SOLID97
PSOLID
SOLID98
PSOLID
SOLID117
PSOLID
SOLID147
PSOLID
SOLID148
PSOLID
SOLID164
PSOLID
SOLID185
PSOLID
SOLID186
PSOLID
SOLID187
PSOLID
SOLID191
PSOLID
SOLSH190
PSOLID
SOLID226
PSOLID
SOLID227
PSOLID
SOLID285
PSOLID
SHELL28
PSHELL
SHELL41
PSHELL
SHELL43
PSHELL
SHELL51
PSHELL
SHELL57
PSHELL
SHELL63
PSHELL
SHELL91
PCOMP
SHELL93
PSHELL
SHELL99
PCOMP
SHELL131
PCOMP
SHELL132
PCOMP
SHELL143
PSHELL
SHELL150
PSHELL
SHELL157
PSHELL
SHELL181
PCOMP OR PSHELL
SHELL281
PCOMP OR PSHELL
PLANE2
PSHELL
PLANE13
PSHELL
PLANE25
PSHELL
PLANE35
PSHELL
PLANE42
PSHELL
PLANE67
PSHELL
PLANE75
PSHELL
PLANE77
PSHELL
PLANE78
PSHELL
PLANE82
PSHELL
PLANE83
PSHELL
PLANE121
PSHELL
PLANE145
PSHELL
PLANE162
PSHELL
PLANE183
PSHELL
PLANE223
PSHELL
PIPE16
PBEAM
COMBIN14
PBUSH
MASS21
CONM2
MPC184
PBUSH
See Also:
ANSYS Conversion Tools
