CFD has the following boundary condition tools:
Create Single Component |
Opens a dialog to create a single component. |
Create CFD Components |
Functionality to define the standard CFD collectors. In the dialog, the commonly used collectors names, such as inflow, are pre-selected. Components can be added or removed from the list and a multiplier for each component can be defined. By clicking Create the selected components are created and appear in the Model browser. |
Delete data from a model database, preview and delete empty collectors, and preview and delete unused property collectors, material collectors or curves. |
Find the free edges in a group of elements, find "T" or discontinuous connections in a group of elements (any edges connected to three or more elements), display duplicate nodes and equivalence duplicate nodes. |
Hand-build, combine, split or modify elements. |
Select the type of element to create and also allows you to change existing element types. |
Opens the Faces panel. This panel is used to generate the bounding or exterior surface elements (^faces collector) that will be used to define surface zones for the different boundary conditions. |
Create hidden line plots of the displayed structure. Also contains the Clip Boundary Elements tool, which allows you to visually sweep the cutting section for greater viewing clarity. |
Reorganize your database by copying or moving data (entities) among collectors or includes. |
