Often it may happen that boundary layer elements will have bad quality due to high aspect ratio. Such elements are created because of the large boundary edge length as shown in the following image.
This problem can be resolved by limiting the maximum perimeter elements’ aspect ratio. The maximum boundary elements’ aspect ratio can be achieved using two approaches:
• | By addition of new nodes on the boundary / perimeter. |
• | By node movement on the boundary / perimeter. |
1. | Activate the Allow boundary node insertion checkbox. |
Refine the boundary edges by insertion of nodes on boundary edges. New node insertion is controlled by the specified maximum perimeter element aspect ratio.
Or
Activate the Allow boundary node movement checkbox.
This option is used to move boundary nodes along the original boundary. Boundary node movement is controlled by the specified maximum perimeter element aspect ratio.
Enter the maximum perimeter element aspect ratio as shown in the following image:
2. | Click Generate 2D BL Mesh to generate the mesh. If the model already contains collectors 2DBLMesh and 2DCoreMesh, then a pop-up message will ask you if you want to delete components 2DBLMesh and 2DCoreMesh before mesh creation or if you want to add newly created elements to the same collectors. Most of the time you will want to clear the existing mesh: click Yes. In some special cases you may want to keep them. |
When this task is finished, two collectors 2DBLMesh and 2DCoreMesh are updated with new elements as shown in the following image:
3. | You can check the element’s aspect ratio by using the shortcut key F10 and selecting the 2-d page. |
When the perimeter has sharp angles as shown in the following image, triangular elements are added to the boundary mesh to achieve a smoother transition of element sizes, and mesh smoothing also contributes to increase the mesh quality.
Also note that the automatic mesh generator performs a collision detection and avoids boundary layer interference by reducing the boundary layer thickness, as shown in the following inset:
