The window viewing options allow you to zoom in and out of the currently displayed window, specify an area to see in closer detail, fill the window with the model and refresh the screen.
The following window viewing options are included as default keyboard shortcuts:
z |
Circle zoom: click-and-drag the mouse to draw a circle. The view zooms to that circle when you release the mouse button. |
+ and - |
(Numeric keypad) Current Window Zoom |
f |
Fit to screen |
p |
Plot (refreshes the rendering in the graphics area). |
s |
Slide zoom; click-and-drag the mouse to zoom in and out. Release the mouse button to stop zooming. |
CTRL - right-click allows you to drag the model.
Engineering Solutions displays a message requesting you to circle the area of the model to be more closely investigated.
A trailer line appears wherever the mouse is moved. The area circled is used to recalculate the window when the mouse button is released.
These two functions increase or decrease the current window by the user-defined factor specified on the modeling subpanel on the Options panel. |
The cursor changes to dynamic center mode.
Automatic full screen refreshes are kept to a minimum. If the screen appears messy or inaccurate after entities have been plotted and erased, press the P key to refresh the screen. The model and/or the window are not resized when you refresh the screen. |
or
