Engineering Solutions
Using View Rotation
Using View Rotation
Using View Rotation
There are multiple methods you can use to rotate a displayed model.
Use the left, right, up and down arrow keys to rotate the model incrementally.
Hold down the CTRL key, then click-and-drag on the model in the graphics area.
Click the user view button on the toolbar to access the View menu, then click cw (clockwise) or ccw (counterclockwise).
view_menu
The View menu
See Also:
Display Controls
