Engineering Solutions
Setting Basic Views
Setting Basic Views
Setting Basic Views
The View pop-up menu allows you to display your model in several basic views, reverse the view, or rotate the model in clockwise or counterclockwise directions. The save and restore options allow you to save, identify and restore different views of your model.
view_menu
View pop-up menu
See Also:
Display Controls
