Engineering Solutions
Connector Entity
Connector Entity
Connector Entity
Connectors are geometric entities (not FE) used to create connections between components. Connectors are used to realize FE idealizations of the physical connection. Just as you create an FE mesh on a surface, you create FE connections by realizing a connector.
The characteristics of connector entities can be divided into four categories:
Connector Terminology
Connector Definition
Connector Realization
Connector Review
Connectors are created and modified within the Connectors Module.
See Also:
Connectors Module
