For this tutorial it is recommended to complete the introductory tutorial RD-3520: Pre-Processing for Pipes Impact Using RADIOSS for basic concepts on the RADIOSS interface.
In this tutorial you will learn how to set up a RADIOSS input deck for analysis of the impact of a bumper against a barrier behind a rigid wall. The modeling steps that are covered are:
• | Associating /PART, with /MAT and /PROP. |
• | Converting node-to-node connections (/RBODY) into a mesh-less welding formulation (/INTER/TYPE2 with /SPRING) using connectors. |
• | Defining the contact for the elements in the bumper with an /INTER/TYPE7 card. |
• | Defining the interaction between bumper and barrier with an /INTER/TYPE7 card. |
• | Defining the interaction between barrier and rigid wall with the /RWALL/PLANE and /BOX/RECTA cards. |
• | Specify the output of resultant forces for a plane on the left interior and exterior crash boxes with /SECT. |
• | Creating a /TH/NODE card to output time history for nodes. |
The units used in the model are millisecond, millimeter and kilogram (ms, mm, kg), and the tutorial is based on RADIOSS Block 14.0.
The model used consists of a simplified bumper model (see image below):
Bumper model
The model file used in this exercise can be found in the es.zip file. Copy the file(s) from this directory to your working directory.
1. | From the Start menu, select Engineering Solutions > Crash (HyperMesh) or click on the Standard toolbar. |
2. | Select Crash and RADIOSS. |
1. | In the Standard toolbar, click the Open Model icon and browse to select the bumper.hm file. |
2. | Click Open. The model loads into the graphics area. |
1. | In the Model browser, right-click and select Create > Component. The Entity Editor (EE) will open. |
2. | For Name, enter Vehicle mass. |
3. | Set Card Image to None and click Yes to confirm. |
4. | Click Geometry > Create > Nodes > XYZ to open the Nodes panel. |
5. | In the x field, enter 700. |
6. | In the y field, enter 0. |
7. | In the z field, enter 170. |
8. | Click create to create the node. |
9. | Go to the Setup page, and click rigids. |
10. | Click the selector arrow nodes 2-n: and select sets. |
11. | For primary node, select the node created in the steps above. |
12. | Click sets and select the Constrain Vehicle set. |
13. | With all the DOF’s checked, click create to create the rigid body. |
Note: | A spider will be drawn connecting the created node to the edge nodes of the structure modeled. |
14. | Click the Card Edit icon in the Collectors toolbar, set the selector to elements and select the rigid body created. |
16. | Fill the mass and inertia information in the card image, as shown in the table below: |
Mass
JXX
JXY
JXZ
JYY
JYZ
JZZ
800
1.5E+07
-5.0E+03
-8.0E+06
5.0E+07
-900
6.0E+07
17. | Set ICOG as 4 and set Ispher as 0. |
18. | Click return to exit the panel. |
1. | Click View > Solver Browser to activate the Solver browser, if it is not active on your screen. |
2. | In the Solver browser, right-click and select Create > BOX > BOX/RECTA. The Entity Editor opens. |
3. | For Name, enter box velocity. |
4. | Optionally, select a Color. |
5. | Enter Corner1 and Corner2 X, Y, and Z coordinates, as shown below. |
1. | Select BC's Manager from the Utility menu or click the BCs Manager icon in the Crash toolbar. |
2. | In the BCs Manager, enter Name as tran_vel. |
3. | Select the Select type as Initial Velocity under the Create header. |
4. | Set the entity selector to BOX under GRNOD. |
5. | Click on it and select box velocity. |
6. | Enter -10, 0, 0 for Vx, Vy and Vz fields, respectively. |
7. | After the above step, a set named InitialVelocity_grnodbox is created automatically or you can create this set before the above step and then refer to this set in the above step, instead of BOX. |
8. | Click the Create > Close. |
1. | In the Solver browser, right-click and select Create > SURF_EXT > PART. The Entity Editor opens. |
2. | For Name, enter barrier_surface. |
3. | For Entity IDs, click on Components. |
4. | In the Select Components dialog, select barrier and click OK. |
5. | In the Solver browser, right-click and select Create > SURF > PART. The Entity Editor opens. |
6. | For Name, enter bumper_surface. |
7. | For Entity IDs, click on Components. |
8. | In the Select Components dialog, select bumper, exterior crashbox left, exterior crashbox right, interior crashbox left, and interior crashbox right and click OK. |
9. | In the Solver browser, right-click and select Create > SURF > SURF. The Entity Editor opens. |
10. | For Name, enter barrier_bumper_surface. |
11. | For Entity IDs, select Sets. |
12. | Click on Sets and select barrier_surface and bumper_surface and click OK. |
1. | In the Solver browser, right-click and select Create > INTER > TYPE7. The Entity Editor opens. |
2. | For Name, enter impact. |
3. | For Grnod_id (S) (slave entity), set the selector to Components. |
4. | Click Components, select bumper, interior crashbox (left and right) and exterior crashbox (left and right) and click OK. |
5. | For Surf_id (M) (master entity), set the selector to Set. |
6. | Click Set, select barrier_bumper_surface and click OK. |
8. | For the static coefficient Fric, enter 0.15. |
1. | Click the Display Numbers icon on the Display toolbar. |
2. | Click the node selector and select by ID. |
3. | For the IDs enter 6227, 6224, 5993. |
4. | Check the display checkbox on. |
Note: | Node numbers will appear next to the node for selection in further steps. |
6. | From the Setup page, click systems. |
7. | Go to the create by node reference page. |
8. | Select Node ID 6224 for origin node. |
9. | Select Node ID 6227 for z axis. |
10. | Select Node ID 5993 for yz plane. |
11. | Click create to create a system. |
12. | Click the Card Edit icon on the Collectors toolbar. |
13. | Set the entity selector to systs. |
14. | Select the system and click edit. |
15. | Change the option from Skew to Frame. |
1. | In the Solver browser, right-click and select Create > GRSHEL > SHEL. The Entity Editor opens. |
2. | For Name, enter CrosssectionPlane-elements. |
3. | For Entity IDs, toggle to Elements selector active, select two rows of element on either side of the system, as shown in figure below. |
1. | In the Solver browser, right-click and select Create > SECT > SECT. |
2. | For Name, enter Crosssection_Plane. |
3. | For Frame_ID, select the system defined in the previous step by clicking on the screen. |
4. | For grshel_ID, select the set CrosssectionPlane-elements which is defined in previous step, as shown below. |
1. | Right-click in the Solver browser and select Create > TH > SECTIO. |
2. | For Name, enter Section_force. |
3. | For Entity IDs, toggle Crosssections and select Crosssection_Plane. |
4. | For NUM_VARIABLES, select 1 and for Data: Var, enter DEF. This selects the default output for RADIOSS. |
These nodes will be slave to the rigid wall.
1. | In the Solver browser right-click and select Create > BOX > BOXRECTA. |
2. | For Name, enter half model. |
3. | Optionally, select a Color. |
4. | Enter Corner1 and Corner2 X, Y and Z coordinates, as shown below: |
5. | Right-click in the Solver browser and select Create > GRNOD > BOX. |
6. | For Name, enter RigidwallSlave_grnodbox. |
7. | For Entity IDs, set the selector to Box and select the above created half model (BOX/RECTA). |
1. | Press the F8 key to enter the Create Nodes panel. |
2. | Select the XYZ ( ) subpanel. |
3. | For x=, y= and z=, enter the values –600, -750 and 90, respectively. |
5. | In the Solver browser, right-click and select Create > RWALL > PLANE. |
7. | Set Geometry type as Infinite Plane. |
8. | With the Base node selector active, select the node that was created in step 4. |
10. | For grnod_id1 (S), toggle Set and select RigidWallSlave_grnodbox (GRNOD/BOX). |
11. | For fric, specify 1.0 for the friction coefficient. |
1. | Launch the Solver browser by clicking View > Solver Browser. |
2. | Right-click in the Solver browser general area to create the cards, shown below, with the given values for each parameter: |
Keyword Type
Keyword
Parameter
Parameter Value
CONTROL CARDS
TITLE
Status
[Checked]
CONTROL CARDS
TITLE
TITLE
Bumper_Impact
ENGINE KEYWORDS
RUN
Status
[Checked]
ENGINE KEYWORDS
RUN
Tstop
20
ENGINE KEYWORDS
PARITH
Status
[Checked]
ENGINE KEYWORDS
PARITH
Keyword2
ON
ENGINE KEYWORDS
PRINT
Status
[Checked]
ENGINE KEYWORDS
PRINT
N_Print
-1000
ENGINE KEYWORDS
TFILE
Status
[Checked]
ENGINE KEYWORDS
TFILE
Time Frequency
0.1
ENGINE KEYWORDS
ANIM/ELEM
Status
[Checked]
ENGINE KEYWORDS
ANIM/ELEM
EPSP
[Checked]
ENGINE KEYWORDS
ANIM/ELEM
VONM
[Checked]
ENGINE KEYWORDS
ANIM/BRICK/TENS
Status
[Checked]
ENGINE KEYWORDS
ANIM/BRICK/TENS
STRESS
[Checked]
ENGINE KEYWORDS
ANIM/BRICK/TENS
STRAIN
[Checked]
ENGINE KEYWORDS
ANIM/SHELL/TENS/STRESS
Status
[Checked]
ENGINE KEYWORDS
MEMB
[Checked]
ENGINE KEYWORDS
ANIM/SHELL/TENS/STRAIN
Status
[Checked]
ENGINE KEYWORDS
MEMB
[Checked]
ENGINE KEYWORDS
ANIM/VECT
Status
[Checked]
ENGINE KEYWORDS
ANIM/VECT
DISP
[Checked]
ENGINE KEYWORDS
ANIM/VECT
VEL
[Checked]
ENGINE KEYWORDS
ANIM/DT
Status
[Checked]
ENGINE KEYWORDS
ANIM/DT
TStart
0
ENGINE KEYWORDS
ANIM/DT
Tfreq
1
ENGINE KEYWORDS
DT/NODA
Status
[Checked]
ENGINE KEYWORDS
DT/NODA
CST 0 – Tmin
3.6e-4
1. | Click File > Export or click the Export icon . |
2. | For File, click the folder icon and navigate to the destination directory where you want to run. |
3. | Enter the name as bumper_impact and click Save. |
4. | Click the downward-pointing arrows next to Export options to expand the panel. |
5. | Toggle Merge starter and engine file to export the engine file with the model file. |
6. | Click Export to export both model and engine file. |
1. | Go to Start > Programs > Altair HyperWorks <version> RADIOSS. |
2. | For Input file, browse to the exercise folder and select the file bumper_impact_0000.rad. |
The exercise is complete. Save your work to a HyperMesh file.
