Create new materials from the Material dialog. Specify the following options and click Create to create the material and return to the Material macro, or Create/Edit to create the material and open the card image panel in HyperMesh to specify the material’s properties.
Material Set No |
Type a number for the material set. If you do not specify a value, a number will be automatically provided that is one higher than the highest current material set number. |
Material Name |
Type a name to identify the material. |
Material Type |
Select MP or MPDATA depending on the material card you want to use. |
