Engineering Solutions
ANSYS Utility Menu
ANSYS Utility Menu
ANSYS Utility Menu
The ANSYS Utility menu is loaded when you open the ANSYS user profile. The macros on the ANSYS Utility menu simplify some common tasks for the ANSYS user profile. The following ANSYS macros are available.
Component Manager
Displays components and attributes in an interactive table.
Material
Creates and defines material cards.
Section
Creates and defines section cards.
Real Sets
Creates property card images for elements defined with the ET Type macro.
ET Type
Creates HyperMesh card images for ANSYS element types.
Contact Manager
Creates new contact pairs and manages existing contact pairs.
Convert to Spl. 2nd Order
Converts a first-order meshed part to a special second-order meshed part.
Update Pre-8.0 HM Model
Updates older model files.
See Also:
ANSYS Interface Overview
