Engineering Solutions
ANSYS Real Sets Macro
The Real Sets macro creates property card images for all elements that the ANSYS interface supports.
real_sets_macro
With this macro, you can view the real constant values of existing real sets, create new real sets, and edit the properties and reference numbers of existing real sets.
The Real Sets macro dialog displays the real set, reference numbers, element type of the property set, and the real constant values for that element type.
Rows can be sorted by set name, set ID and the element type column.
The following buttons are available on the Real Sets macro dialog:
Help
Provides information about the macro.
New…
Opens the Create Real Sets dialog, from which you can specify parameters for a new real set and create it.
Edit…
Opens the Edit Real dialog, from which you can review and change parameters for an existing real set that is selected in the table.
Export
Allows you to export the table in .csv format
Refresh
Refreshes the HyperMesh database with changes you made through the Real Sets macro.
Delete
Deletes the real set(s) that is selected in the table.
Close
Closes the Real Sets macro dialog.
Right-clicking on a row displays a context sensitive menu with the option to delete unused real constants. Selecting this option can help you clean up your model by deleting unused real constants.
You can also edit real sets, edit real constants, and delete real sets from the menu that appears when you right-click in the table when a row/real set is selected.
real_sets_macro_02
See Also:
ANSYS Utility Menu
ANSYS Interface Overview
