Engineering Solutions
Create Real Sets Dialog
Create new real sets from the Create Real Sets dialog.
Specify the following options and click Create to create the real set and return to the Real macro, or Create/Edit to create the real set and open the card image panel in HyperMesh to specify the real constants for the element type.
Real Set No
Type an identification number for the real set. If you do not specify a value, a number will be automatically provided that is one higher than the highest current real set ID number.
Element Type
Select an element type from the drop-down list for which a real set is to be created. The element types are listed in groups sorted by type, as shown in the image below.
ansys_real_macro2
