Engineering Solutions
ANSYS Section Macro
ANSYS Section Macro
ANSYS Section Macro
The Section macro creates and defines section cards for beam and shell sections. You can create new section, edit existing sections, and use the HyperBeam application to create and edit beam section and associate them to section cards.
section_macro
The following buttons are available on the Section macro dialog:
Help
Provides information about the macro.
New…
Opens the Create Section Dialog, from which you can specify parameters for a new section and create it.
Edit…
Opens the Edit Section Dialog, from which you can review and change parameters for an existing material that is selected in the table.
Refresh
Refreshes the HyperMesh database with changes you made through the Material macro.
Delete
Deletes the section card(s) that is selected in the table.
Close
Closes the Section macro dialog.
Right-clicking on a row displays a context sensitive menu with the option to delete unused sections. Selecting this option can help you clean up your model by deleting unused sections.
You can also edit sections, edit section properties, and delete sections from the menu that appears when you right-click in the table when a row/section is selected.
section_macro_02
See Also:
ANSYS Utility Menu
ANSYS Interface Overview
Edit Section Dialog
To Create a SECDATA Card with the Section Macro
