Engineering Solutions
Creating an XY Plot
Creating an XY Plot
Creating an XY Plot
Each xy plot  window is assigned a name when you create it.  Plot attributes include the title, subtitle, and labels, and also the margin and border around the xy plot.  These attributes can be adjusted before or after you add curves to the plot.
The first step in the process of creating an xy plot is to use the Plots panel to name and create an xy plot collector.  Default values are initially assigned to the xy plot attributes.
See Also:
Plots panel
XY Plotting
