The XY Plots module is a group of panels that perform operations on plots and the curves displayed on those plots.
To access the XY Plots module, select the XY Plots drop-down menu.
The xy plotting panels are described below:
The Axis Labels panel allows you to modify the x and y axes titles and labels. You can also change the color and font size used to display these entities. |
The Axis Scaling panel allows you to modify the starting and ending values of the plot axes. You can set the values explicitly or implicitly by using the panel functions such as find curves, circle zoom, and zoom out. |
The Border panel allows you to change the thickness and color of the border around the plot. You may also specify whether the border is displayed and the size of the margin between the border and the plot. |
The Curve Attribs panel allows you to change the color, marker style (used to indicate the point location), thickness and the line style (solid, dashed, and so on). You can apply a scaling factor to the original data points. You can also change the curve title that appears in the legend. |
Creates and modifies the curves in the database. This panel allows you to read data vectors from files as well as perform advanced mathematical operations on curves. |
The Grid Attribs panel allows you to change the color, line style, thickness of the grid lines, and the margin displayed around the grid lines. |
The Grid Labels panel allows you to change the color, font, and number of significant places in the labels. Grid labels appear along the x and y axes in the plot (tick marks). |
Calculates and displays the integral of a curve. |
The Legend panel allows you to change the location and the font used to display the legend. |
The Plot Titles panel allows you to change the plot title, subtitle, and label. In addition, you can change the color and font size used to display these entities. |
Allows you to create an xy plot and assign curves to the xy plot. |
Allows you to determine the coordinate values of points in a curve. |
Reads curves from an ASCII file. |
Allows you to rename curves. |
Generates a curve from the currently-selected results file. |
Allows you to perform simple mathematical calculations on a curve. |
In addition, you can use the Curve Editor to view and modify curves already defined in your model.
