Engineering Solutions
Cross Sectional Properties Calculated by HyperBeam
The beam cross section is always defined in a y,z plane. The x-axis is defined along the beam axis. The coordinate system you define is called the local coordinate system; the system parallel to the local coordinate system with the origin in the centroid is called the centroidal coordinate system; the system referring to the principal bending axes is called the principal coordinate system.
For shell sections, only the theory of thin walled bars is used. This means that for the calculation of the moments and product of inertia, terms of higher order of the shell thickness t are neglected. Thickness warping is also neglected.
Area
Area Moments of Inertia
Area Product of Inertia
Radius of Gyration
Elastic Section Modulus
Max Coordinate Extension
Plastic Section Modulus
Torsional Constant
Solid
(see below for warping function)
Shell open
Shell closed
Elastic Torsion Modulus
Solid
Shell open
Shell closed
Shear Center
Warping Constant (normalized to the shear center)
Shear deformation coefficients
Shear stiffness factors
Shear stiffness
Warping Function
For solid sections, the warping function is computed using a finite element formulation. This may lead to un-physically high stresses in geometric singularities (sharp corners) that get worse with mesh refinement. This may cause problems computing the elastic torsion modulus.
Nastran Type Notation
hbeam_nastran_type_notation
