Engineering Solutions
Design Variable Links entityDesignVariableLinks-24
Previous topic Next topic Expand/collapse all hidden text
Design variable link entities are used to define links between design variables for optimization problems.  Design variable links are shown under the DesignVariableLink folder within the Model browser.  The Optimization View can be utilized to create, edit, and delete optimization problems.
Design variable links do not have a display state.
Design variable links have an active and export state.  The active state of a design variable link controls the listing of the design variable link in the Model browser and any of its views.  If a design variable link entity is active, then it is listed in the Model browser and any of its views.  If a design variable link entity is inactive, then it is not listed in the Model browser or any of its views.
The export state of a design variable link entity controls whether or not that design variable link is exported when the custom export option is utilized.  The all export option is not affected by the export state of a design variable link.  The active and export states of design variable link entities can be controlled using the Entity State browser.
The data names associated with design variable links can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit design variable links:
Desvar Link
Solver Card Support for Design Variable Links
hmtoggle_arrow1OptiStruct
An optimization problem is set up by defining responses, which are in turn constrained or set as objectives.
Design variables identify the varying quantities in an optimization problem.
All of the optimization panels are available from the Optimization menu when the OptiStruct user profile is loaded.
Supported Card
Solver Description
Supported Parameters
Notes
DLINK
Design variable link. Supported as a designvariablelink entity.
Used to define links between DESVARs.
designvariablelink
Defined in the Desvar Link panel.
DLINK2
Defines a link of one design variable to one or more other design variables defined by a DEQATN card.
hmtoggle_arrow1Nastran
Some of the functionality of the optimization capability is general. This includes the equation utility, delete, rename, renumber, and reorder functions. To set up an optimization problem, responses, an objective function and constraints need to be defined. Further, design variables need to be defined. The optimization panels have separate Delete, Rename, Renumber, and Reorder panels to manipulate optimization entries.  These can be reached through the Optimization drop down menu.
Supported Card
Solver Description
Notes
DLINK
Relates one design variable to one or more other design variables.
DLINK2
See Also:
Optimization Browser View
Browsers
Entities & Solver Interfaces
Include Files
Optimization
