The Dummy browser is available in the Crash LS-DYNA and RADIOSS user profiles.
Open the Dummy browser from the menu bar by clicking Safety > Dummy Positioner.
The Dummy browser is used to position a dummy model.
This browser is compatible with all LS-DYNA and RADIOSS Humanetics dummies (encrypted or not encrypted) and also with LSTC dummies.
You can undo and redo actions made in the browser using the Undo and Redo commands on the Restore toolbar.
The Dummy browser consists of two panes. The first pane displays the dummy structure which consists of the different bodies defining the dummy model. The second pane displays the Entity Editor in which positioning parameters for each dummy articulations can be defined. The following data is displayed in the Dummy browser:
The Entity Editor is used to assign, modify, and quickly view the attributes defined inside Dummy browser entities. In the Entity Editor you can define the H-Point coordinates or apply Global rotations on the dummy to position the dummy in space. The H-Point coordinates can be directly specfied in the fields, or by clicking on the blue arrow, which then enables you to select a target location by picking a node in the graphics area. Global rotations on the dummy can also be defined. The magnitude of the rotation can be modified, using the up and down arrow buttons. Moreover, you can control the increments of the operations by changing the Increment value. The Entity Editor is also used to modify the position of bodies. You can directly define the angle of rotation to apply in each axis of rotations in which the selected body is able to move. The magnitude of the rotation can be also modified, using the up and down arrow buttons. Moreover, you can control the increments of the operations by changing the Increment value.
The Dummy (
See Also:
