Engineering Solutions
FBD Displacements
FBD Displacements
FBD Displacements
The FBD Displacements utility extracts displacement data for user defined node set(s), and is useful for doing breakout modeling within a sub-modeling scheme.
After you define an element set with an associated node set, all appropriate displacements and rotations are extracted.  Results can be output to load collectors for graphical review, a text summary table, and a formatted .csv file which can be loaded into traditional spreadsheet software packages.
See Also:
FBD Overview
Tab area
