Engineering Solutions
FBD Forces
FBD Forces
FBD Forces
The FBD Forces utility extracts grid point force data (including forces and moments) for a user-defined element set, and is useful for doing breakout modeling within a sub-modeling scheme.
Results can be output to load collectors for graphical review, a text summary table, and/or a formatted Comma-Separated Values (.csv) file which can be loaded into traditional spreadsheet software packages.
The FBD Forces utility is broken down into three major sections, each of which corresponds with the process order of using the tool.
See Also:
FBD Overview
Tab area
