Select the desired loadstep(s) from the list in the loadstep section.
The loadstep section lets you specify from which loadstep(s) to extract GPFORCE information. Loadsteps with GPFORCE results from the currently selected results file display for selection only. Multiple loadsteps can be selected by Ctrl-clicking and Shift-clicking. The list can be filtered using the buttons provided, including a name filter that uses standard Engineering Solutions filtering syntax. The loadstep list can be organized by ID or Name (ID).
The ID option lists the loadsteps as "SUBCASE #". The Name (ID) option lists the loadstep as "SUBTITLE – LABEL (ID)". If no SUBTITLE exists, only the LABEL is used. See the OptiStruct online reference guide for more information regarding SUBTITLEand LABEL loadstep information cards.
