Engineering Solutions
Finding Connectors
Finding Connectors
Finding Connectors
The Connector browser provides several ways to locate specific connectors in an interactive way:
The find attached function can be used for connectors in two different ways.
Connectors and certain entity types are attached via the link definition on the connector, so connectors can be found by selecting link entities, or link entities can be found by selecting attached connectors.
The between function allows you to find connectors that are shared by two or more of a selected link's entities.
The Find panel allows you to use the find entities function to find individual connectors in your model.
When you find connectors, you will often want to display realized FE as well.  To aid in this, the found connectors can be saved in the user mark.
See Also:
Connector Browser
