Panel |
Description |
Create or update accelerations. |
Generate fluid-volume meshes for acoustic testing. |
Add entities to existing connectors. |
Create and update masses applied to nodes. |
Create and modify input data pertaining to the Arbitrary-Lagrangian-Eulerian LS-DYNA capability. |
Control the display of the model during animation sequences. |
Use a "dummy" connector entity to add mass to a part, or create areas of mass to represent parts not present in the CAD or FE data. |
Apply a displacement result to the nodes. |
Create area-type connectors, such as adhesives. |
Create collections of components. |
Performs automatic geometry cleanup and prepares it for meshing based on the parameters set in the panel. |
Interactively or automatically create meshes on surfaces. |
A panel for most of the plate and shell meshing operations that allows you to work interactively on mesh parameters. |
Edit axis label information. |
Modify plot axes. |
Create or update bar2 or bar3 elements. |
Calculate beam section properties. |
Create components that group beamsections together. |
Create and modify block entities. |
Create and modify HyperMesh group entities that correspond to OptiStruct body definitions. |
Create and realize bolt connectors. |
Edit the border of an XY plot. |
Redefine the layout of the HyperMesh menu system. |
Select the entities that are viewed in the card image subpanel. |
Used to generate hybrid grids, containing hexa/penta elements in the boundary layer and tetra elements in the core or fare field. |
Verify the quality of elements. Check warp, aspect, skew, angles, length, jacobian, connectivity, and duplicates. |
Modify the color attributes of collectors. |
Compare connectors. |
Create components that group data together. |
Align the element material angle of a mesh of shell elements and review material angle and ply directions. |
Define manufacturing constraints for composite sizing optimization. |
Define manufacturing constraints for composite shuffling optimization. |
Create a surface or mesh for cones or cylinders. |
Change the configuration of existing elements. |
Create and manage connectors. |
Define data for truncation threshold and maximum number of constraints to be retained per region, per load case for a given response type. |
Create or update constraints or enforced displacements on nodes. |
Create and modify contactsurf entities. |
Create contour or assignment plots of results. |
Edit solver specific data on a set of entities. |
Create control volumes. |
Exchange some data between different solver formats. |
Sums the entities in the database. |
Create and edits curves. |
Create constraints for optimization problems. |
Remove surface features. |
Create deformed plot based on displacement results. |
Delete data from the database. |
Find nodes that have multiple DOF constraints. |
Create user-defined functions for constraints and/or objective functions. |
Link a design variable to other design variables. |
Detach elements from adjoining elements. |
Change one or more dimensions of existing geometry |
Define a discrete design variable value table for use in size or shape optimization. |
Find the distance or angle between nodes. |
Add and edit domains or update the model. |
Create a surface or mesh by dragging nodes, lines, or elements. |
Rotate the dummy assemblies or specify the position of the H-Point of a dummy assembly. |
Perform many edge-specific operations such as suppressing or combining. |
Finds free edges and equivalences nodes on edges. |
Create or edit new or existing curves from files or math expressions. |
Build, combine, and split elements. |
Improve element quality of a selected region. |
Create solid elements or layers of plate or shell elements based on a plate or shell element by offsetting the shell elements in a direction normal to the surface they form. |
Select and change existing element types. |
Create and modify single or multiple ellipsoids and cylinders. |
Create sets of nodes or elements. |
Create, review, and update equations. |
Find free faces and equivalences nodes on surfaces. |
Write stress/strain results from finite element analysis to an external file that can be used to set up fatigue analysis in a supported fatigue solver. |
Provide access to the Finite Difference panel. |
Create or modify Finite Difference blocks. |
Add (absorb) existing FE weld entities as realization to connectors. |
Create, review, or update joints. |
Display the edges of a model as one dimensional plot elements, providing a visualization tool to see the edges of a complex model. |
Find entities (and IDs) in the database. |
Create or update flux loading to nodes. |
Create or update forces. |
Morph mesh without domains, handles, or morph volumes. |
Define design domains for free shape optimization. |
Define design domains for free size optimization. |
Create or update gap elements. |
Create a single design variable (DESVAR) and multiple property relation (DVPREL1) cards for the components selected for size optimization. |
Specify the template file, current component, element order and size. |
Edits grid information. |
Edits grid label information. |
Add and edit handles, or save to or load from a file. |
Create hidden line and shaded image plots of elements. |
Define beam section entities before entering the HyperBeam module. |
Launch the HyperLaminate module. |
Create constraints that restrict the movements of nodes or force compliance with dimensional requirements during morphing. |
Prepare and morph models. |
Parameterize solver models for performing parametric, optimization, or stochastic studies. |
Open a browser to display information on the models’ connectors. |
Integrate a curve. |
Create and modify interfaces that define a contact or sliding surface. |
Create, review, or update joint elements for MBD simulation. |
Edit the plot legend. |
Determine the length of a group of selected lines. |
Create a surface or mesh by dragging nodes, lines, or elements along a line. |
Combine lines, splits lines at a point, at a joint, at a line, or at a plane, and smoothes lines. |
Create 1D elements between nodes or along a line. |
Create one dimensional plot elements. |
Create solid elements between two groups of plate elements. |
Create lines using a variety of methods. |
Create components that group loads together. |
Map loads or boundary conditions from geometrical entities to associated FE mesh entities. |
Create and update collections of load collectors. |
Select load types for new models or updates load types as defined in a template file. |
Map parts of the model to lines or surfaces. |
Create and modify markers. |
Mask entities from the display list. |
Obtain the mass, area, and volume of selected elements or surfaces. |
Create or update mass elements. |
Create components that group materials together. |
Define kinematic joints between two local coordinate systems to connect two multibody collectors. |
Create rectangular, planar surfaces for use in multibody analysis. |
Extract the midsurface representation of a solid part. |
Create or update moments. |
Morph a model and create shape entities. |
Create and manipulate morphing volumes. |
Set restraints on morphing. |
Edit options that affect morphing behavior. |
Create components that group multibodies together. |
Associate, move, or place nodes on a surface. |
Create nodes using a variety of methods. |
Display and adjust the normal of elements or surfaces. |
Add non-structural mass entities to a model, or modify existing ones. |
Display the IDs of entities. |
Define objective functions for optimization problems. |
Define a response and its reference values for a minmax (maxmin) optimization problem. |
Control the optimization process. |
Determine tolerance, zoom factor, element shrink, pick handles, and so on. |
Perform topology, topography, size, and shape optimizations. |
Write out OptiStruct input files and then solve by clicking the optistruct button. |
Change elements from first to second order, or vise versa. |
Move or copy entities between components. |
Extract and import the final design geometry from OptiStruct’s topology, topography, and shape optimization results into HyperMesh. |
Create and update blocks of entities used for output requests. |
Check groups for initial penetration problems. |
Setup shape optimization. |
Switch x, y, z data of entities. |
Create a planar surface or mesh bounded by planar lines. |
Edit plot titles. |
Create new plots and select curves to include on the plot. |
Add, move, and edit fixed points. |
Create free points using a variety of methods. |
Position entities in space by selecting nodes. |
Create, remove, and view preserved nodes. |
Create or update pressures. |
Project entities to a plane, vector, or surface. |
Create components that group properties together. |
Perform FE quality checks. |
Calculate a single value to represent the quality of the displayed shell (2D) model. |
Find the x and y values of a point in a curve. |
Collects many tools for minor edits of model geometry. |
Execute a RADIOSS run on your desktop from HyperMesh. |
Create or update RBE3 elements. |
Input an xy data set from an ASCII file. |
Mirror entities about a plane. |
Change collector names. |
Renumber entities. |
Change the order of named entities in the database. |
Manually equivalence nodes. |
Create responses for an optimization. |
Create curves by extracting data from a HyperMesh results file. |
Create and modify simple ribs between two surfaces. |
Create and update rigid walls. |
Create or update rigid or rigidlink elements. |
Create or update rod elements. |
Rotate entities about a vector. |
Create a surface or mesh from nodes or lines which are unconnected. |
Contains the panels used for safety analysis. |
Modify the size of entities. |
Create connectors that represent line connectors. |
Create and route seatbelts onto a dummy. |
Create and edit sensors. |
Perform shape optimization. |
Create and apply shapes to morph meshes. |
Create a loose or tight shrink-wrap mesh over a model. |
Perform simple math functions on a curve. |
Setup and perform size optimization. |
Create a surface or mesh skin across a set of lines. |
Improve element quality on a surface mesh. |
Analyze the behavior or fluid or gas inside a meshed part. |
Trim/split or merge solid entities |
Create a solid mesh by defining source, destination, and along surfaces. |
Create a solid mesh within a volume defined by edge lines. |
Create solids using a variety of methods. |
Run an external program from within HyperMesh or assign and run a solver. |
Create a spherical surface or mesh. |
Focus on a specific area of a model by displaying only the model inside a three dimensional sphere, masking everything outside the sphere. |
Create a surface or mesh by rotating nodes, lines, or elements about a vector. |
Create a surface or mesh with lines. |
Split elements into pre-defined patterns. |
Create connectors. |
Create or update spotweld elements. |
Create or update spring elements. |
Generate NASTRAN and OptiStruct subcase definitions. |
Create a summary of elements, loads, and properties. |
Assign nodes to a super element set and display the nodes of a super element set. |
Trim surfaces with lines or surfaces, untrims surfaces, and create surfaces that fill gaps in the model. |
Set the transparency level for the surfaces of selected components. |
Create surfaces using a variety of methods. |
Create components that group coordinate systems together. |
Create local coordinate systems. |
Specify values for the constraints used in defining functions. |
Assign names to entities. |
Add or remove temporary nodes. |
Create or update temperatures. |
Fill an enclosed volume with first or second-order tetrahedral elements. |
Create and edit screen titles. |
Setup and define topography optimizations. |
Setup and define topology optimizations. |
Create a toroidal surface or mesh. |
Create an animation sequence from transient results. |
Move entities along a vector. |
Remove existing welds. |
Displays version, update, and systems information. |
Store and retrieve specific views of the current model. |
Create components that group vectors together. |
Create a vector entity. |
Create vector plots from vector quantity results. |
Create or update velocities. |
Controls xy plot window size and placement. |
Contains the xy plotting panels. |
