HyperStudy can be used to perform Design of Experiments (DOE), optimization, and stochastic studies in a CAE environment. It allows you to study the different aspects of a design under various conditions, including non-linear behaviors. It can be applied in the multi-disciplinary optimization of a design combining different analysis types.
In addition to standalone use, HyperStudy can be directly accessed from HyperMesh by clicking HyperStudy from the Applications menu.
When HyperStudy is accessed from within HyperMesh, you have direct access to the HyperMesh database to perform the design parameterization.
The following user profiles and solvers are supported:
The following entities in HyperMesh can be accessed for the purpose of defining design variables:
• | In addition, models can also be parameterized using a base input template derived from the ASCII solver input. |
See Also:
What is HyperStudy?
Hyperstudy Graphical User Interface
HyperStudy Tutorials
