Engineering Solutions
Masking Connectors
Masking Connectors
Previous topic Next topic Expand/collapse all hidden text
Masking Connectors
Masking turns off the display of connectors in the graphics area. When masking connectors, you can also mask the corresponding realized FE.
The Connector browser provides several ways to mask specific connectors in a more interactive way. The Mask panel can also be used to mask connectors.
How do I...
hmtoggle_arrow1Mask or unmask connectors
1.In the Connectors module, select the Mask panel.
2.Select the mask or unmask subpanel.
3.Click the entity selector switch and select connectors.
4.Indicate which connectors you want to mask or unmask by selecting them on your model, or click the connectors collector and choose from the extended entity selection menu.
5.Click mask or unmask.
Note:When masking or unmasking connectors, you can choose to mask/unmask the corresponding realized FE by activating the include realized FE check box. Click unmask all to redisplay all masked connectors, but also all other masked entities.
