Engineering Solutions
Graphics Window
Graphics Window
Graphics Window
The graphics area displays a representation of the geometric layout of the section. All sections display the following items:
Item
hbeam_y_z
Local origin of the beamsection
hbeam_section_centroid
Section Centroid
hbeam_shear_center
Shear Center
element_axis
Element Axis
Standard sections display the geometric representation of the section based on the parameter values, which are also listed on the screen.
hbeam_graphics_standardsectiondisplay
For shell sections each part is drawn with lines connecting the dots that show the section's vertices.
hbeam_graphics_shellsectiondisplay
Solid sections can be created and edited using the same tools as a shell section, and the mesh that is used for the section calculations is displayed.
hbeam_graphics_solidsectionsdisplay
Since generic sections do not inherently have any shape, only a grey box is shown. The centroid and shear center graphics location will update.
hbeam_graphics_genericsectiondisplay
