Engineering Solutions
Displaying Stress Recovery Locations
You can turn the display of stress recovery location's points and/or prop IDs, that are already defined within the property solver cards, on and off by modifying the display parameter. Stress recovery points for shells, solids, and generic sections are only supported in the Nastran, RADIOSS, and OptiStruct user profiles. To access these parameters, click Parameters > Display from the menu bar. To accept your changes, click Update before you exit the dialog.
stress_recovery_locations
