Engineering Solutions
HMENT
HMENT
HMENT
NAME
HMENT – This card is used for preservation of the ADMASS card upon import in RADIOSS.
SYNTAX
HMENT elem_id vis_nod node_id
TYPE
HyperMesh Comments
DESCRIPTION
elem_id
Element Identification number
vis_nod
node_id
Node_id
SUPPORTED SOLVERS
OptiStruct
See Also:
HyperMesh Comments
Working with Files
