Engineering Solutions
HMERROR
HMERROR
HMERROR
NAME
HMERROR - An export comment that detects a problem upon export.
SYNTAX
HMERROR type
TYPE
HyperMesh Comments
DESCRIPTION
The HMERROR comment is output when the HyperMesh template detects and/or corrects a problem during creation of the deck. It is included to inform you of possible problems with the deck.
type
text
SUPPORTED SOLVERS
See Also:
HyperMesh Comments
Working with Files
