Engineering Solutions
HMFIXEDSURFPOINT
HMFIXEDSURFPOINT
HMFIXEDSURFPOINT
NAME
HMFIXEDSURFPOINT – A comment used to describe weld points for the automesher.
SYNTAX
HMFIXEDSURFPOINT x y z suppressed
TYPE
HyperMesh Comments
DESCRIPTION
The HMFIXEDSURFPOINT comment is used to describe weld points for the automesher. X, Y and Z are 16-character real numbers that describe the x, y, z location of the fixed point and suppressed is an eight-character integer describing the type of fixed point.
x
X location of the fixed point.
y
Y location of the fixed point.
z
Z location of the fixed point.
suppressed
An eight-character integer describing the type of fixed point.
SUPPORTED SOLVERS
See Also:
HyperMesh Comments
Working with Files
