Engineering Solutions
HMFOOTERBEGIN
HMFOOTERBEGIN
HMFOOTERBEGIN
NAME
HMFOOTERBEGIN - An import comment to that indicates the beginning of the footer for the deck.
SYNTAX
HMFOOTERBEGIN
Comment 1
Comment 2
Comment 3
HMFOOTEREND
TYPE
HyperMesh Comments
DESCRIPTION
The $HMFOOTERBEGIN card indicates the beginning of footer notes in the deck. Any number of comment lines can be placed after this line. The end of this block is indicated by a $HMFOOTEREND statement. Only one footer documentation block is allowed per model.
Comment 1
Text entered
SUPPORTED SOLVERS
OptiStruct
See Also:
HMFOOTEREND
HyperMesh Comments
Working with Files
