Engineering Solutions
HMFOOTEREND
HMFOOTEREND
HMFOOTEREND
NAME
HMFOOTEREND - An import comment to that indicates the end of the footer for the deck.
SYNTAX
HMFOOTERBEGIN
Comment 1
Comment 2
Comment 3
HMFOOTEREND
TYPE
HyperMesh Comments
DESCRIPTION
The $HMFOOTEREND card indicates the end of the footer notes in the deck. The begining of this block is indicated by a $HMFOOTERBEGIN statement. Only one footer documentation block is allowed per model.
Comment 1, 2, 3, and so on.
Text entered
SUPPORTED SOLVERS
OptiStruct
See Also:
HMFOOTERBEGIN
HyperMesh Comments
Working with Files
