Engineering Solutions
hmnastf06 Utility
hmnastf06 Utility
hmnastf06 Utility
hmnastf06 translates Nastran *.f06 ASCII files into HyperMesh binary results files. hmnastf06 reads only the GPSTRESS output from the .f06 file for SOL101 analyses. The syntax to run the translator is:
hmnastf06 [arguments] <inputfile> <outputfile>
where [arguments] are the optional arguments. To obtain the arguments, use the command hmnastf06 -u.
hmnastf06 arguments are on by default.
Notes:
hmnastf06 requires that FIBRE ALL is used in the SURFACE command during analysis
hmnastf06 organizes the GPSTRESS results into simulations based on subcase ID and surface ID/volume ID
See Also:
hmnast
hmnasto2
hmnastopt
Nastran Interface Overview
