Engineering Solutions
hmnastopt Utility
hmnastopt Utility
hmnastopt Utility
hmnastopt translates Nastran SOL 200 punch files into HyperMesh binary results files. hmnastopt requires the following options in the dat file:
DISPLACEMENT(PUNCH) = ALL
STRESS(PUNCH) = ALL
ANALYSIS = STATICS
ANALYSIS = MODES
PARAM, DESPCH>0
The syntax to run the translator is:
hmnastopt [options] <inputfile> <outputfile>
Note:Use the command hmnastopt -u to obtain information about the options. The –h3d flag outputs file to an H3D file instead of to an hmresults file. The file includes model and results information that was translated. The model must contain geometry for it to be output to an H3D file. If the punch file contains the keywords GRID and DESVAR, the option -bulk <bulkfile>must be provided. To generate HyperMesh compatible x-y plot data (design cycle number vs. thickness), use the option -plot <plotfile>.
See Also:
hmnast
hmnasto2
hmnastf06
Nastran Interface Overview
