Engineering Solutions
Translating Complex Results
Magnitude and phase values are always used to contour plot the complex results. Therefore, if the Nastran output is in the form of real and imaginary numbers, hmnast and hmnasto2 will calculate the corresponding magnitude and phase.
The results will then be obtained using the following equation:
You can choose the value of when viewing the result by specifying the angle on the Contour or Deformed panel.
