Engineering Solutions
To Post-Process Nastran Results
Before viewing the result file, make sure that the model is loaded.  The model can be loaded prior to or after translating the result file.
To Translate Nastran Results
1.Click File > Load > Results File.
2.Browse to select the binary results file generated by the hmnast, hmnast02, or hmnastf06 translator.
3.Click Open.
To View the Contour Result
1.Open the Contour panel.
2.Click simulation= to choose simulation title.
3.Click data type= to choose the data to be simulated.
4.Click contour to view the smooth transition result.
Or
Click assign to view the border line result.
To View the Deformed Result
1.Open the Deformed panel.
4.Click deform to view deformation in static condition.
Or
Click linear to view deformation in dynamic condition.
To View the Transient Result
1.Open the Transient panel.
2.Click start with= to choose the beginning of the transient simulation.
3.Click end with= to choose the end  of the transient simulation.
4.Click data type= to choose the data to be simulated.
5.Click transient.
Note:This is applicable for time dependent analysis such as modal analysis (sol 103), and so on.
