Engineering Solutions
HyperBeam Results Pane
Whenever HyperBeam computes the section properties of the current section, it displays them in the Results pane. You cannot edit the text in this portion of the window for standard, shell and solid sections, but you can select it and copy/paste it into another application. The only way to change the parameters of a generic section is to edit the values in the Results Pane.
hbeam_results_pane
