Engineering Solutions
Importing and Exporting Connectors
The standard Import and Export tabs can be used to import connectors from and export connectors to an HMASCII file.  In addition, a simplified readable connector definition can be imported from and exported to a Master connectors file.  Finally, you can also export or import an XML connector file.
Only the information required for definition and creation of connectors such as location coordinates, entities to connect (such as assemblies or comps as the link types), and their connector rules are exported.
