Use the series of action mode tools on the right-hand side of the Link Entity browser to control both entity selection and the display of the model in the graphics area.
The behavior of the action mode tools depends on the settings of the view options. When all of the view options are inactive (gray background), the core behavior of the action mode tools work exactly as they do in the Model browser. If you select one or more of the view options, the behavior of the show, hide, isolate, and isolate only options change and a connector symbol appears in the icon. In this mode, you are able to select entity links in the graphics area instead of entities. The entity links you are able to select depends on the view option you select.
The table below explains the different action mode tools.
Icon |
Description |
Use the next and previous tools to cycle through the selected links in the Link Entity browser. To activate these tools, select link entities in the browser. These tools will be especially helpful to you when not all of the selected links can be seen in the partial view of the list. |
Use this tool to select a type of entity that the rest of the action mode tools will act on. For example, when you set this tool to "components", the Selector tools (described below) will only be able to select or deselect component links. This icon is always disabled and set to the entity type that is defined by the view mode you have selected. |
Use this tool to determine whether the rest of the action modes tools will act on:
If you select elements only, you can still perform actions on connectors (geometric entities) by selecting their link entities. However, any actions taken (such as Isolate) will only affect the entity types specified by this tool. In the case of geometry only, only the connectors with at least one link state defined as "geometry" are taken into account. Since you can define connectors as linking elements, surfaces, or a combination of both, this tool affects actions taken on them in a similar manner. For example, if you set the tool to "elements only" but select a connector that only connects geometry, the actions you might take on that connector will not affect it. However, if the connector links both geometry and elements, then any actions you might take will still apply to the connector due to the element links. |
Use the Selector tool to interactively select and find any type of supported link entity in the browser or graphics area. For example, when you select a link entity in the graphics area, Engineering Solutions highlights it in the browser. This is an efficient way of selecting and finding multiple link entities at once. You can use this tool in conjunction with the show, hide, isolate, and isolate only action mode tools, as well as with the show/hide connectors between and isolate/isolate only connectors between advanced action tools. To use the Selector tool in conjunction with the other tools listed above, select the link entities in the browser or graphics area and then click the desired action mode tool.
In other respects, the Selector tools behaves exactly as it does in the Model browser. |
The Add to Panel Collector is a function whereby the browser can be used to select and add entities to the panel collectors within HyperMesh. This is an alternative method to using the advanced selection capabilities already available in each panel collector's extended entity selection menu. This button only becomes available when you have a HyperMesh panel open that includes at least one entity collector. |
Use the Show/Hide tool to display or hide selected entites. The behavior of this tool will depend on the view options settings. Click this option to activate it, and then select the desired links in the graphics area. Engineering Solutions hides the selected links and any other entities found by the view option settings.
Use this option to isolate/isolate only selected entities. The behavior of this tool will depend on the view options settings. Click this option to activate it, and then select the desired link entity in the graphics area.
