Engineering Solutions
Load Step: CFILM
Load Step: CFILM
Load Step: CFILM
The CFILM dialog allows you to define the *CFILM card on node sets.  To open the dialog in the Load Step window, open Concentrated loads in the tree, select CFILM, and select a load collector from the Load Collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_cfilm_define_tab
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
