Engineering Solutions
Abaqus Utility Menu
Abaqus Utility Menu
Abaqus Utility Menu
The following macros are included on the Abaqus page of the Utility menu when you load the Abaqus user profile.
Utility
Solid Face Alignment
3  Standard3D, Explicit
Align Faces
Determines the default stack or thickness direction for Abaqus composite solid, gasket and continuum shell elements.
Review
The Review button opens the Element Selector panel and allows you to pick solid elements. Selected elements are highlighted. When you click proceed, it highlights the face1 of selected solids and draws an arrow along the default stack (or thickness) direction of selected solids.
Reset
The Reset button deletes the stack (or thickness) direction arrows.
Dummy
Applies to templates: Explicit
Positioning Process Manager
Tool that guides you through a workflow of positioning a dummy in a seat.
Tools
Applies to templates: Standard2D, Standard3D, Explicit
Contact Comparison
Activates the Tie-Comparison tool, from which you can compare the Tie-Contact elements created in HyperMesh to the Tie-Contact elements created by the Abaqus Solver.
Step Manager
Activates the Abaqus Step Manager, which allows you to define Abaqus history (*STEP) information in Engineering Solutions.
Contact Manager
Activates the Abaqus Contact Manager, which allows you to create, edit and review the following cards in Engineering Solutions:
*CONTACT
*CONTACT DAMPING
*CONTACT PAIR
*FRICTION
*PRE-TENSION SECTION
*SHELL TO SOLID COUPLING
*SURFACE, TYPE = ELEMENT
*SURFACE, TYPE = NODE
*SURFACE, COMBINE
*SURFACE, CROP
*SURFACE, TYPE = CUTTING SURFACE
*SURFACE, TYPE = CYLINDER, REVOLUTION or SEGMENTS
*SURFACE INTERACTION
*SURFACE BEHAVIOR
*TIE
Find and Replace
Searchs the entity names in your model for every occurrence of a specific character, and automatically replaces the character with a new one that you specify.
SPH Mesh
Generates SPH elements for selected components in your model.
