The Abaqus Contact Manager allows you to create, edit and review the following cards in Engineering Solutions:
• | *SHELL TO SOLID COUPLING |
• | *SURFACE, TYPE = ELEMENT |
• | *SURFACE, TYPE = CUTTING SURFACE |
• | *SURFACE, TYPE = CYLINDER, REVOLUTION or SEGMENTS |
The Abaqus Contact Manager is organized into three main tabs:
Interface
Surface
Surface Interaction
To start the Contact Manager:
2. | Click Contact Manager in the Abaqus Utility menu. |
The following rules apply when you are using the Abaqus Contact Manager.
• | When the Contact Manager window is minimized or it is behind the Engineering Solutions window, restore it by clicking the Contact Manager button in the Abaqus Utility menu. |
• | To display the bubble help for a button, place the cursor over the button for a few moments. |
• | Double click on the interface, surface and surface interaction names in the table to open the corresponding edit windows. Right-click on the names to display pull-down menu options. |
• | Table columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button, and dragging the border to a new position. |
• | The shift and CTRL keys can be used with a left mouse click to select multiple items in a table. |
• | Press CTRL and the left or right arrow key to move the cursor within the active cell. Use the left, right, up and down arrows to change the active cell. |
• | Right-click on the Review button to clear the review selections. |
• | If you create, update or delete components, groups, properties, or entity sets from Engineering Solutions panels while the Contact Manager is open, click the Sync button to update the Contact Manager with the new changes. |
• | In the Friction and Surface Behavior tables, right click in the tables to display a pull-down menu containing copy, cut and paste options. Comma delimited data can be copied, cut, or pasted in these tables. Relevant hot keys, for example, CTRL-c, CTRL-x, and CTRL-v on PC, will also work. |
• | In some fields in the Contact Manager, you can access the Entity browser, which is available via the (…) button. The Entity browser makes it more convenient to view and sort long lists of components or other entities when selecting them for the field. |
