Engineering Solutions
Load Steps: FILM: Delete Tab
The Delete tab allows you to delete FILM and other loads from Engineering Solutions.  There are three deletion options:
All loads in current collector
The Delete button deletes all the loads from the current load collector.
All 'Distributed loads' in current collector
The Delete button deletes all distributed (*DLOAD, *FILM) loads from the current load collector.
By selection
The Pick Loads button opens the Load Selector panel. Pick the loads you want to delete and click proceed.
The corresponding Reset button resets the selected loads.
The Delete button deletes the selected loads.
step_mgr_film_delet_tab
See Also:
Load Step: FILM
