Engineering Solutions
Load Step: Parameter
The Parameter option in the tree allows you to define the parameters of the *STEP card.
The supported parameters are:
Name, Amplitude, Extrapolation, Unsymmetric, Increment, Nlgeom, and Perturbation
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the parameters defined in the database.
step_mgr_parameter
See Also:
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
