Engineering Solutions
LS-DYNA to Nastran Conversion
Use the Conversion tool to convert a LS-DYNA file to a Nastran file.
1.Load the LS-DYNA user profile.
2.Import a LS-DYNA model.
3.To run the conversion macro, from the menu bar, click Tools > Convert > LS-DYNA > To Nastran. The Conversion tab opens.
4.To start the conversion, click Convert. After the conversion, the Nastran user profile automatically loads.
5.Review and export the deck using the Nastran user profile. Some of the keywords in the LS-DYNA deck are converted to the Nastran deck as per the following tables.
Element Mapping
LS-DYNA type
Nastran type
*ELEMENT_MASS
CONM2
*ELEMENT_INERTIA
CONM2
*ELEMENT_BEAM
CBAR
*ELEMENT_SHELL
CTRIA3,CQUAD4, CQUAD8, CTRIA6
*ELEMENT_SOLID
CTETRA4/CHEXA8/CPENTA6
*CONSTRAINED_SPOTWELD
RBAR
*ELEMENT_PLOTEL
PLOTEL
*CONSTRAINED_INTERPOLATION
RBE3
*CONSTRAINED_NODE_SET
RBE2
*ELEMENT_DISCRETE
CELAS1
Property Mapping
LS-DYNA type
Nastran type
*SECTION_SOLID
PSOLID
*SECTION_SHELL
PSHELL
*SECTION_BEAM
PBAR, PBARL
*SECTION_BEAM with ELFORM 1 is mapped to the PBARL property.
*SECTION_BEAM with ELFORM 2 is mapped to the PBAR property.
Material Mapping
All the LS-DYNA materials are mapped MAT1 in Nastran.
Boundary Conditions Mapping
LS-DYNA type
Nastran type
*BOUNDARY_SPC
SPC
*LOAD_NODE_POINT
FORCE, MOMENT
*LOAD_SEGMENT
PLOAD4
*INITIAL_TEMP
TEMP
Coordinate System Mapping
LS-DYNA type
Nastran type
*DEFINE_COORDINATE_NODE
CORD1R
*DEFINE_COORDINATE_SYSTEM
CORD2R
See Also:
LS-DYNA Conversion Tools
