Engineering Solutions
LS-DYNA to RADIOSS Conversion
Use the Conversion tool to convert a LS-DYNA file to a RADIOSS file.
1.Load the LS-DYNA user profile.
2.Import an LS-DYNA model.
3.To run the conversion macro, from the menu bar, Tools > Convert > LsDyna > To RADIOSS. The Conversion tab opens.
4.Click Convert. After the conversion, the RADIOSS user profile automatically loads.
5.Review and export the deck in the RADIOSS user profile. Some of the keywords in the LS-DYNA deck are converted to the RADIOSS deck as per the following tables.
Element Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*ELEMENT_SHELL
SHELL, SH3N
*ELEMENT_SOLID
BRICK, TETRA44
*ELEMENT_MASS
ADMAS
*ELEMENT_BEAM
BEAM
*ELEMENT_DISCRETE
SPRING2N
*ELEMENT_SEATBELT_ACCELEROMETER
ACCEL
Load Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*BOUNDARY_SPC_NODE/SET
BCS
*LOAD_NODE_POINT/SET
CLOAD
*INITIAL_VELOCITY_NODE/GENERATION/ RIGID BODY
INIVEL
System Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS  type
*DEFINE_COORDINATE_NODES
SKEW/MOVE/
*DEFINE_COORDINATE_SYSTEM
SKEW/FIXED
Material Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*MAT_ELASTIC
M1_ELASTIC
*MAT_PLASTIC_KINEMATIC
M36_PLASTIC_TAB
*MAT_NULL
M0_VOID
*MAT_RIGID
M1_ELASTIC (nodes of material defined as /RBODY)
*MAT_PIECEWISE_LINEAR_PLASTICITY
M36_PLAS_TAB
*MAT_SIMPLIFIED_JOHNSON_COOK
M2_PLAS_JOHNS_ZERIL
Properties Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS  type
*SECTION_BEAM
P3_BEAM
*SECTION_DISCRETE
P4_SPRING
*SECTION_SHELL
P1_SHELL
*SECTION_SOLID
P14_SOLID
Curve Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*DEFINE_CURVE
FUNCT
Control Cards Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*CONTROL_ADAPTIVE
ADMESH_GLOBAL, ADMESH_SET
Component Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS  type
*DAMPING_PARTS_OPTIONS
PART
*PART_OPTIONS
PART
*INCLUDE_STAMPED_PART
PART
Contact Interface Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*CONTACT_AUTOMATIC_GENERAL
INTER/TYPE7
*CONTACT_AUTOMATIC_GENERAL_INTERIOR
INTER/TYPE7
*CONTACT_AUTOMATIC_NODES_TO_SURFACE
INTER/TYPE7
*CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE
INTER/TYPE7
*CONTACT_AUTOMATIC_SINGLE_SURFACE
INTER/TYPE7
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE
INTER/TYPE7
Rigid Wall Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS type
*RIGIDWALL_GEOMETRIC_FLAT_OPTIONS
RWALL
*RIGIDWALL_PLANAR_OPTIONS
RWALL
Time History Definition Mapping
HM configuration,
LS-DYNA type
HM configuration,
RADIOSS  type
*DATABASE_HISTORY_BEAM
TH/BEAM
*DATABASE_HISTORY_NODE
TH/NODE
*DATABASE_HISTORY_SHELL
TH/SHEL
*DATABASE_HISTORY_SOLID
TH/BRIC
*DATABASE_HISTORY_TSHELL
TH/THSH
The attributes converted in each KEYWORD is explained in the Conversion dialog (see below). Each keyword is associated with a color to distinguish it better.
GREEN – All the attributes of the KEYWORD are converted to equivalent in RADIOSS.
ORANGE – Only some the attributes of the KEYWORD are converted to equivalent in RADIOSS.
RED – None the attributes of the KEYWORD are converted to equivalent in RADIOSS. Conversion of this keyword is not supported by the conversion tool.
ls-dyna_to_radioss_conversion_tab.zoom75
See Also:
LS-DYNA Conversion Tools
