»Click here to display Table of Contents« The Engineering Solutions User Interface > Working with Files > Retrieving and Saving a File:
The simplest way to open an .hm model database is to use the Open option located in the File menu.
Open invokes the file browser so that you can navigate to the desired file directory and select a file to open.
See Also:
